Dell Dimension 3000
First post, by Damian Fallas
i just get a Dell Dimension 3000, and Im trying to install Windows 98, but cant fint the correct drivers, does someone sucessfully install W98 in this machine?
Reply 1 of 1, by Repo Man11
Looking it up it's a 2004 machines with an Intel 865 chipset motherboard, so Win98 shouldn't be a problem. The driver pack from 2003 on this page should take care of most of what you need, though you might still have to search for a driver for the network port. https://www.philscomputerlab.com/intel-chipset-drivers.html
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
