First post, by Demetrio
Hi,
I'm having some problem running Half-Life 2 and the Episodes on my Windows XP retro pc.
I read hl2 is DRM-free so I tried to copy the games folders, inside the Steam directory, from my Windows 11 PC to the Windows XP PC and launch
hl2.exe
from the command prompt but nothing happened (no error messages of some sort).
I tried with some arguments, like
hl2.exe -hushsteam
without luck.
What am I doing wrong?
These are the WinXP PC specs:
  • CPU: Pentium 4 630 3GHz
  • RAM: 1GB DDR2
  • Video card: Nvidia GeForce 7800GT 256MB
  • OS: Windows XP Service Pack 2
Thanks in advance.
Reply 1 of 25, by RandomStranger
Yeah, it's weird. I've never tried the current steam version on XP before, I always went for the original 2004 version. I just tried now and I experience the same on XP, but it runs without issues on Vista on the same machine:
https://gamesystemrequirements.com/user/rando … /devices/289374
The current version of HL2 runs on a much more modern version of the Source Engine. Maybe it simply lost compatibility with XP.
Reply 2 of 25, by DosFreak
Last time I tested HL2 on XP was with build v5377866 from back in 2019 or 2020?
According to my Black Mesa folder with bms.exe dated 12/26/2019 that works in XP but the one dated 12/28/2020 does not so it's certainly possible between 2019 and now support was dropped from HL2 for XP.
If true shouldn't take much to perform a diff between new and old folders to find the difference.
Portal 2 also dropped XP support a loooong time ago so you have to use old build v4560 to run it in XP.
Try the following switches:
hl2.exe -game hl2
hl2.exe -game episodic
hl2.exe -game ep2
hl2.exe -game lostcoast
hl2.exe -game hl1
hl2.exe -game portal -console -window
Make your games work offline
Reply 3 of 25, by Demetrio
DosFreak wrote on 2022-04-05, 21:22:
Last time I tested HL2 on XP was with build v5377866 from back in 2019 or 2020? According to my Black Mesa folder with bms.exe d […]
hl2.exe -game hl2
hl2.exe -game ep2
hl2.exe -game hl1
Is there a way to rollback to v5377866?
Edit: I rolled back to the previous build through Steam and now it works!
Anyway, thanks for the help 😀
Reply 5 of 25, by DosFreak
Confirmed, v7122284 doesn't work on XP.
Well that's weird, previous build in steam is v2257546 which is extremely old. I'll stick with v5377866 from 2019 for HL2.
Portal not working, use v1910503
Half-life 2 update is working v2257546
Reply 6 of 25, by Demetrio
Now I'm having issues with Portal, because there's no previous build option for this game.
I've tried downloading the 2014 build with this method: https://steamcommunity.com/sharedfiles/filede … /?id=2353930763 and placing it in the Portal directory but it did not work.
I believe the cause are the dll files inside bin, which are missing from the depot.
Edit: I just needed to download the Windows client depot, which contains the required bin files.
Now It works flawlessly!
Reply 7 of 25, by FFXIhealer
Now that I've seen this thread....
(turns on XP gaming PC and tries to open Half-Life 2)
...Damn. Same here. Gotta install older versions of this game now. Maybe this will fix my Athlon XP based system to play one of the original versions of this game. All of my CD/DVD-based copies of this game are all Steam enabled and Steam absolutely hates the original and won't let me run them. It forces me to update the game instead, breaking compatibility with the Athlon XP by forcing SSE2 extensions.
Ooof. Got to the Steam Console part and when I put in the command to download an older version of Half-Life 2, I got:
Depot download failed : error downloading manifest 6200972686848870847 (Access Denied)
Looks like I'll only be playing this on my Windows 7 machine for the time being. I swear this game worked on my laptop years ago and for over a decade, AND it should have originally ran on my Athlon XP system when it was first released.
STEAM! Making games unplayable on their original systems since 2004!
Reply 8 of 25, by Demetrio
FFXIhealer wrote on 2022-04-24, 12:46:
Now that I've seen this thread.... […]
Try with DepotDownloader: https://steamcommunity.com/sharedfiles/filede … /?id=2353930763
It worked for me 🙂
Reply 9 of 25, by lafoxxx
Get Vivendi version (Collector's Edition), works for me. You bought the game anyway, so it's not piracy.
Reply 10 of 25, by silentsoul
How could I roll back to v5377866? Is it too late?
I would like to have that (final XP compatible) build with Ep1+Ep2+Lost Coast+Portal (I own these games on Steam).
Reply 11 of 25, by DosFreak
If you never previously backed up that version then you can try checking steamdb for the manifestid for HL2 from 2019 and then use the above links or various guides on how to download old versions of games from steam.
Reply 12 of 25, by silentsoul
I did backup a build but turns out it wasn't v5377866... Thanks for your help, I'll check if Steam has still got it!
Reply 13 of 25, by silentsoul
Managed to download it but when I want to start the game (hl2.exe -game hl2) nothing happens...
Is v5377866 DRM free?
Reply 14 of 25, by Demetrio
silentsoul wrote on 2024-09-21, 12:38:
Yes it is, I have it in my P4.
Maybe you're using the most updated bin/ files, which are incompatible with the 2019 version.
If so, download the 2019 Windows client depot with DepotDownloader.
It should be this: https://steamdb.info/depot/222/history/?chang … 907925122915749 (ManifestID: 8161907925122915749)
Reply 15 of 25, by silentsoul
Demetrio wrote on 2024-09-21, 12:53:
Yes it is, I have it in my P4. […]
No luck unfortunately... I'm probably doing something wrong.
1, downloaded the latest version of the game via steam
2, downloaded the 2019.09 manifest via depotdownloader
3, copied everything over from the downloaded depot folder to the original steam folder where the latest version was (overwrote all files)
Am I missing something?
Reply 16 of 25, by Demetrio
silentsoul wrote on 2024-09-21, 13:21:
No luck unfortunately... I'm probably doing something wrong. […]
Did you download both?
Reply 17 of 25, by silentsoul
Demetrio wrote on 2024-09-21, 13:32:
Did you download both? […]
Yes. I did the whole thing again and now it works... go figure. Thanks anyway for the tip on the client!
Now I just need to figure out how to add portal on top of all this (HL2, EP1, EP2, LC). As that depot is from 2014 (and the rest is from 2019), will it break anything?
Reply 18 of 25, by Demetrio
silentsoul wrote on 2024-09-21, 13:41:
You're welcome 🙂
Regarding Portal... Yeah, I think you need the 2014 Windows client (ManifestID: 5794932327719644273): https://steamdb.info/depot/402/history/?chang … 932327719644273
Reply 19 of 25, by DosFreak
I don't have my server in front of me but Portal is in a seperate folder not combined with the older Valve HL2 engine games
Portal v1910503 (12/2014)
Works on 2000 w/bwc and above
