Basically it only has jumpers for voltage and multiplier — it won't give you support for 100MHz CPUs unless your board supports it. And if your board does have support for 100 MHz FSB, it can likely use those chips without any upgrade kit (just maybe need a BIOS upgrade for plus CPUs, depending on the board).
So AMD K6-2@400 is the highest clocked 66MHz CPU and there's that.
I've heard some people change the chip to K6-2+/3+ just for setmul support and (maybe) more cache. The chip will work at 66 MHz, but you'll be able to set the Spectra to 2V. I must tell you that the chip sits pretty flush on the kit. I haven't found the courage to try and remove mine (not that I need that terribly).
The user Dragon Caesar did that here, though
