First post, by mrfusion92
Hi, today I tested a Panasonic JU-475-4 5.25'' floppy disk. It came with ten floppies, I couldn't read any of them. Seller claimed drive was working, didn't say anything about the floppies.
When it tries to read a floppy, the head just moves back and forth a little and then stops, the "device not ready" message appears after that. The head movement is very short.
I cleaned the head with alchol and lubrificated everything. I can guarantee that the motor is working okay, I actually verified that by chance.
I setted the disk number jumper of this drive to 1. Tried to boot PC and happened that the 5.25 and the other 3.5 floppy disk started to move synchronously (in the 3.5 there was a win98 boot floppy). The head was moving perfectly fine and PC actually booted from the 3.5 floppy.
So do I have bad floppies? I don't have others to test sadly.
