First post, by Damian9303
- Newbie
It's rather hilarious checking up on eBay listings with laptops that sellers went on a long "quest" of sorts to find, assuring it’s the most "powerful" one capable of running much older operating systems such as Windows 2000, while subtly explaining the absence of vital drivers like though they're only minor inconvenience; all the while asking a fortune for a laptop that normally costs considerably less on any other version of Windows. The only missing driver here is the webcam due to the absence of Windows’ Image Acquisition (WIA). Which yeah I'm aware about the existence of BlackWingCat’s Extended Core, but the main purpose here is to see how much is possible without it (at the very most, having drivers with utilities that only work with their Extended Kernel)
Due to the Core 2 Duo being a relatively newer processor, there are some adjustments which have to be made to help with heat management. The most obvious is switching over to the PM timer from the default ACPI timer which'll decrease CPU temps down by 5 degrees, but the SpeedStep applet supplied from Intel (which the latest of can be acquired here: https://www.dell.com/support/home/en-us/drive … ?driverid=c4nr4) is also required in order to support dynamic frequency scaling which’ll knock it down an additional 10-15 degrees, leaving it to where it’d usually be on a fresh installation of Windows XP SP2+. Normally, due to being incapable of utilizing the Core Multiplexing Technologies responsible for allowing a wide range of multiprocessing functions, this applet will only function on a single-core. However, you may try using the following tool in order to remedy the issue: https://gamebanana.com/tools/2614
So here's the list of drivers in order of installation and where they can be downloaded, while some have functional Windows 2000 drivers they may also include utilities that require kernel functions which only work with the Extended Kernel already installed. Hence, I provide both versions depending on which you choose.
"Intel(R) 82801HEM/HBM SATA AHCI Controller" (slipstream with nLite) - https://www.dell.com/support/home/en-us/drive … ?driverid=h36mn
Intel 965PM Mobile Chipset - https://www.dell.com/support/home/en-pg/drive … ?driverid=trdw5
Nvidia GeForce 8400m/8600m GT - https://www.dell.com/support/home/en-us/drive … ?driverid=6gmhm or https://www.driverscloud.com/en/services/GetI … ational-whqlexe (if using the Extended Kernel)
Sigmatel STAC 9228 C-Major HD Audio - https://www.dell.com/support/home/en-us/drive … riverid=r214451
UPEK Fingerprint Sensor - http://oscc.kr/bbs/bbs.php?id=pds&page=1&sn1= … esc=desc&no=178
Dell Wireless WLAN Mini-Card - https://www.dell.com/support/home/en-us/drive … ?driverid=0x3np (if it complains about not finding a supported device, run DellInfo.exe from the setup directory prior to rerunning the setup app)
Dell Wireless Bluetooth Module - https://www.dell.com/support/home/en-us/drive … ?driverid=njnd6 or https://www.dell.com/support/home/en-us/drive … ?driverid=7x5cf (if using the Extended Kernel)
Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller - https://us.driverscollection.com/?file_cid=42 … 3378cb38400c388
Ricoh R5C843/R5C852/R5C592 Controllers - https://download.cnet.com/sp36257-exe/3000-21 … 2_4-165449.html
Ricoh R5C822 SD Host Controller (manually install within Device Manager) - https://dl.driverpack.io/driverpacks/r ... 09-drp.zip
Synaptics PS/2 Touchpad - https://www.dell.com/support/home/en-us/drive … ?driverid=kh5f6
Dell QuickSet - https://www.dell.com/support/home/en-us/drive … ?driverid=dfc1x
The MediaDirect button on the laptop itself may now seem useless, but fret not! So long as Dell QuickSet is present on the system, Media Experience can alternatively be installed through this link: https://archive.org/details/Dell_OEM_Dell_Med … uxe_-_Win95_Eng (though only after installing PowerDVD so to enable DVD playback: https://archive.org/details/pdvd5.3.1012_201910).
