It's indeed a 430VX chipset, you can tell by the larger chip crossed by the blue CD cable in the 2nd pic: Says SB82437VX:
https://en.wikipedia.org/wiki/List_of_Intel_c … entium_chipsets
That means it would take 128 MB, but the cache will only cover 64 MB of it, so little reason to get more.
The type of RAM is simply known as PC-66 SD-RAM, but PC-100 and PC-133 are the same format, only faster and more abundant. Won't make any difference in price or performance on a Pentium system, if you're not going to tweak it.
The standard was a very long lived one, from 1996 till the dominance of DDR around 2001. So, IIRC, there were 1 GB modules around - meaning that 64 MB ones, back then already, were about as obsolete and worthless as 32 MB ones since three 64 MB ones won't get you anywhere on a Athlon Win XP system...
So, whatever you can find for cheap - 2 x 32 or one 64 should work.
Format ist DIMM with 168 pins. That was the one after the 72 pin PS/2 standard:
https://en.wikipedia.org/wiki/DIMM#SDR_168-pin_SDRAM
There used to be "compatibility lists" by motherboard manufacturers if you wanted to make sure a certain brand or model of RAM would play nice with your board. But since 32 and 64 MB DIMMs are on the floor of any hobby workshop, it's probably easier to just try the next best, most should work.
For 64 MB, any BIN above ten quid will be theft and auctions most likely will stall:
https://www.ebay.co.uk/itm/134034486517
I like that blue heatsink, although it's glued on.
Some of that OEM stuff was really neat.
Is that a regular ATX board? Pretty early for a VX chipset.
My very first own PC was a VX, but baby AT - didn't even know of ATX then. Neither did I know about the 64 MB cachable RAM limit - 32 MB already felt much like a luxury 😉
