First post, by maxtherabbit
About roughly 2 years ago I bought a DS12887+ from ebay. Was from a highly rated seller and sold as NOS. 2017 Production date printed on it.
As soon as it arrived, I tested it in a machine and it worked fine. The project I had intended to use it for never materialized, so I stopped the clock as outlined here:
Conserving Dallas RTC chips
Yesterday I received a 486 board with a flat Dallas (socketed). So I decided to pull out my stored away replacement and stick it in there. BIOS is telling me its battery is now low.
Typically I purchase these things from Digikey, but at the time they were out of them or something. Did I get a remarked chip? (I will update the thread this afternoon with a pic, the markings do look different than my other ones)
Or it is possible that something else is going on, a edge case incompatibility with the motherboard where everything else works?
Reply 1 of 7, by TheMobRules
Same thing happened to me a while back... another thing I noticed was that the legs of the chip were unusually thin, which caused a couple of them to break when I removed it. Not sure if we're talking about the same seller but I won't be buying from that one again.
Reply 2 of 7, by maxtherabbit
TheMobRules wrote on 2022-04-12, 14:50:
shit now that you mention it it did go in and out of the socket way too easy
Reply 3 of 7, by maxtherabbit
The attachment 20220412_135534.jpg is no longer available
The attachment 20220412_135515.jpg is no longer available
The attachment 20220412_140052.jpg is no longer available
Definitely a remark job. No way a lithium primary self discharged to 0.9V in 5 years of shelf life without the clock running
Reply 4 of 7, by Horun
Yeah they probably scrubbed and remarked it. I also got some from a well known seller a few years ago that went flat dead very quick.
Another good source in USA is Quest Components, bought many from them and some date stamped year 1999 and were still at 3.2 to 3.3v....
Reply 5 of 7, by brian105
That text on the chip looks way too bright to be legit.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 6 of 7, by dionb
brian105 wrote on 2022-04-13, 08:55:
Not to mention the much-too-smooth finish on the top. That has been polished down.
Reply 7 of 7, by rasz_pl
Dont bother ordering from china, its all pulls or 20 year old stock. Dremel job is maybe max 30 minutes to refurb the old ones.
