First post, by buckeye
Decided to try sata connections on the cd /hard drives but booting from the cd drive initially brought up
the error that it couldn't find the cd driver . After some research found out had to get into the bios and
switch the sata settings to legacy, after that it worked fine.
My question is do I need to switch back to the default sata setting after installing windows or keep it at
legacy? Probably gonna have to take a deep dive into the mobo manual and study up on this.
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 1 of 1, by Robertkopp
You can try switching back when you got the Rudolf Loew sata patch installed. Otherwise it's legacy only, but that is plenty fast for win9x.
https://archive.org/details/@robertkopp
