First post, by notsofossil
For the specific floppy drive sounds I’m referring to, watch the first 20-ish seconds of this YouTube video
https://m.youtube.com/watch?v=OmBLsKV7Sx0
Edit: THIS IS THE VIDEO
https://m.youtube.com/watch?v=SDdfs0XW1kM
Is it only some makes and models of PC desktop motherboard that can do this? Could a SOYO brand board do it?
Thinkpad T42 Win9x Drivers | Latitude D600 Win9x Drivers
Next: Dell Inspiron 8000
Reply 1 of 16, by Cuttoon
You mean the sound of an annoying fat dude babbling away at me about what an old hick I am to have grown up with 33.3? Boy, I want that floppy!
Sure you got the correct url in the clipboard, there?
Also, if you want people to listen to specific things on youtube, try linking to the exact spot, like so:
https://youtu.be/OmBLsKV7Sx0?t=42
cheers
I like jumpers.
Reply 2 of 16, by Meatball
All I hear the first 20 seconds of the video you posted is a modem. If you're serious about floppy drives and not trying to generate traffic for this guy, just about any BIOS with legacy floppy support can be configured with the option "Floppy Drive Seek." Set that to 'enable,' and the drive will make the same noise on bootup as the one in the first video: https://www.youtube.com/shorts/RHvYftuxfRg
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 3 of 16, by Zerthimon
notsofossil wrote on 2022-04-13, 16:08:
How to get PC 1.44MB floppy drives to make sounds during POST?
Set `Boot Up Floppy Seek` to Enabled in the BIOS.
Reply 4 of 16, by debs3759
What a waste of 20 seconds that was. Why did you think it was a floppy drive making dial-up modem handshake sounds?
Reply 5 of 16, by Meatball
debs3759 wrote on 2022-04-13, 18:43:
Might as well make this thread productive. Great database you have setup; I use it frequently for comparing video cards.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
Reply 6 of 16, by Gmlb256
If floppy drives did dial-up modem sounds that would be way cooler and hilarious than the actual floppy sounds done during POST if "Floppy Drive Seek" is supported and enabled which is way shorter. 🤣
Reply 7 of 16, by notsofossil
Oh for fuck sakes, yes I got the wrong fucking video link.
https://youtu.be/SDdfs0XW1kM
There that, the sound of a 1.44MB floppy drive noising away during POST can be heard within the first 10 fucking seconds of that video.
And no I am not trying to drive traffic for that guy. Fuck off.
Ok.... can I have an answer now?
Zerthimon wrote on 2022-04-13, 18:18:
Does that go by any other term?
Reply 8 of 16, by Cuttoon
No worries, that fucking happened to the best of us.
This website of my trust lists several permutations, but they all contain floppy and seek:
https://www.hzdr.de/FWR/VB/BIOS/beff.htm
This here I just copied from a PDF manual of a rather popular 430HX board:
347.78 KiB
- There it is, left column, 8th line.
That's "BIOS feature setup", 2nd screen after the drive details. And of an Award bios, just like with the POST screens in the Video.
Video shows a 430VX chipset, no big difference, but I checket the Manual of a Soyo 5TC with 430FX and Award bios, which does not have the option.
So, some may lack it or it's hidden within the "quick power on self test" option. That will mean you'll have to wait through full RAM test as well.
Use ancient AMI bios around 386 time to get little click sounds for every kB of RAM checked 😉
Hop that clarified the shit out of this matter 😉
I like jumpers.
Reply 9 of 16, by TheMobRules
It's always something of the sort of "Floppy Drive Seek At Boot" in the advanced options menu, but it was removed from BIOS setup utilities as floppies became less relevant. So your motherboard may not even have it. If you tell us what motherboard you are using it would be easier to determine that. The fact that it is a SOYO board is not very helpful in this case, as there have been many SOYO boards from the early '90s to mid '00s.
Reply 10 of 16, by notsofossil
Now these are quality replies I normally come here for, thank you both.
My SOYO board i don’t remember the exact model number of, I do know it’s a Micro ATX (Super) Socket 7 board. Yes it probably is too new for “floppy drive seek on boot” but I’ll look around for that next time I can get to that PC.
Reply 11 of 16, by Meatball
notsofossil wrote on 2022-04-13, 20:43:
Oh for fuck sakes, yes I got the wrong fucking video link. […]
Angry much? if you read past the first few words before wigging out, I wrote the answer and provided a link to the sound. My response was perfectly valid because right at the 20 second mark is when the modem begins to handshake.
Break the Prozac in half next time.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
Reply 12 of 16, by debs3759
Love how quick he makes out he can boot to Windows 😀
Back on topic though, as others say, it's a BIOS setting. Turning off Fast Boot or turning on Floppy Drive Seek (or some similar name) is all you need
Reply 13 of 16, by Gmlb256
No problem, I also understood what you actually needed. And calm down, mistakes can happen. 😉
If the motherboard lacks the option on the BIOS settings you could try MODBIN (the motherboard very likely has Award BIOS) and see if the option could be exposed.
Reply 14 of 16, by Cuttoon
Gmlb256 wrote on 2022-04-13, 21:48:
Yep - for whose who dare.
SS7, chances are there's a modded bios by Mr. Steunebrink for the late AMD chips, btw.
http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm
I like jumpers.
Reply 15 of 16, by Gmlb256
Cuttoon wrote on 2022-04-13, 21:53:
I know that site and tried the GA-586ATV BIOS for a K6-2+ CPU, Jan didn't mod the BIOSes for the OP's purpose though.
Hex editing the BIOS is way more daring and risky than using MODBIN.
Reply 16 of 16, by notsofossil
A modded BIOS that could allow my SOYO SS7 board to be able to select between multiple IDE channels to boot from, or being able to order devices in any way you want would be a fantastic upgrade.
It’s a nice board and everything except you get boot choices like IDE,CD-ROM,Floppy or SCSI,Floppy,CD-ROM and other worthless and random configurations like that.
But, I already have an external CF adapter installed on one of the expansion brackets so it’s fine.
