First post, by Peter Swinkels
Hi,
I am trying to use int 0x21, ax=0x6602 (http://helppc.netcore2k.net/interrupt/int-21-66) to change the code page from inside a Quick Basic program. As far as I can tell I made no mistakes in my program, but the code page will not change. To be more specific: extended characters displayed on screen don't change and int 0x21,ax=0x6601 keeps reporting code page 437 no matter what I do.
The relevant Quick Basic code:
FUNCTION GetCodePageDIM Registers AS RegTypeRegisters.AX = &H6601INTERRUPT &H21, Registers, RegistersGetCodePage = Registers.BXEND FUNCTION'^^^SUB SetCodePage (NewCodePage)DIM Registers AS RegTypeRegisters.AX = &H6602Registers.BX = NewCodePageINTERRUPT &H21, Registers, RegistersEND SUB
I suspect DOSBox doesn't support this function unless I install actual DOS, correct?
EDIT:
I just tested my program in DOSBox-X... and it works! Without modification. Any feedback on the subject is still welcome though! 😀
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
