[Help]An acceptable Windows XP Gaming System
First post, by Regressed93
Hi, I saw this listing on eBay(https://www.ebay.com.au/itm/313877334192?chn= … k0aAgStEALw_wcB) and thought "While it will take me some time before I build my High-End Windows XP gaming PC, this I feel would be acceptable enough to play majority of the games available on Windows XP, if it had a good GPU to go with the cpu"
And this brings me to here, with THIS PC I'm not chasing any granduer all settings maxxed out type of deal, for this PC I'll settle for most settings set to medium, maybe one or two maxxed out at 720p60fps, maybe 1080p60fps at a stretch.
But I'm unsure what gpu would compliment this pc I'm unsure if it is an agp mobo or pci or pci-e, so just to ensure all three connectors are covered maybe reccomend a good gpu for each connector so when i buy the pc and i find out what connector it is using, i can buy the gpu(or an equivalent)that slots into the connector.
I appreciate any and all help provided.
Reply 1 of 78, by The Serpent Rider
Athlon XP 2800+ has acceptable performance for most games until 2005. But I don't see anything appealing in this listing for that price, because it doesn't have video card included. Judging by photos, motherboard might have a dead integrated LAN.
Reply 2 of 78, by Cuttoon
Dude, there's a picture - it's an AGP. 😉
Apart from the fact that there were no Socket A chipsets other than AGP, at least not from VIA, IIRC.
Think that's a VIA KM400 chipset from around 2003, so anything from a Geforce 4 Ti would be somewhat period correct.
But AFAIK, you might as well get anything up to a Gf7 with AGP for a similar price, lower two digits, in an auction.
I used to have this one with WinXP:
https://www.ebay.com/itm/274727064318
Not the fastest Gf7, but simply an awesome design with passive cooling including a heatpipe. May be the most power efficient AGP Geforce out there.
Whether that fit's your request or is already overkill - no idea, some of the many 3D aficionados around here will have to answer that.
But, that Compaq tower you looked at really seems a nice, compact machine, Compaq made some great gear before being gobbled up by those HP suckers. And it comes with SATA, that's a definite plus.
Apart from the GPU, you might wanna get some more DDR SDRAM for that thing, the chipset should accept 4 GB, if the mobo takes 2 GB modules, you'd be all set for SP3 if you want to install that.
Serpent Rider is right though, it's not a great price, you could easily source the parts cheaper. But, that's up to you leisure, I'd say it's a solid base.
I like jumpers.
Reply 3 of 78, by The Serpent Rider
It isn't. VIA had issues with SATA2/SATA3 drives. You need specific HDD/SSD to work around it.
Reply 4 of 78, by Cuttoon
The Serpent Rider wrote on 2022-05-02, 05:10:
That seems to occur a lot, but how could you tell by the photos here?!?
Would be a minor nuisance, if LAN is needed. Especially since it's µATX with limited PCI slots. But, could be worked around with USB.
I like jumpers.
Reply 5 of 78, by The Serpent Rider
PCI LAN.
Reply 6 of 78, by Cuttoon
The Serpent Rider wrote on 2022-05-02, 05:23:
PCI LAN.
Oh, well, erm, good point.
They really should have to declare that, though, at least upon request.
But, can also mean that the PCI card is gigabit while the onboard only 100. Some mobos really were cheap that way, well into the "gigabit mostly for granted" era.
I like jumpers.
Reply 7 of 78, by RandomStranger
Too expensive and only have decent performance for early-XP. You'd probably get a Core2 PC for half the price, add a budget/low-end graphics card from around 2008-2012 and an SB Live! and still come out cheaper.
Reply 8 of 78, by bloodem
As others have mentioned, it's not worth it. Depending on where you live, you could buy something A LOT more powerful for more or less the same amount of money.
For example, in (certain parts of) Europe, with a bit of patience you could buy a Core i5 2500K (or similar) + motherboard + RAM for ~ 50 euros. Throw in a GTX 750Ti which typically also sells for 50 euros, and you've got yourself a killer WinXP rig.
Now, judging from your eBay link, I'm guessing you're from Australia, so not sure what the availability & prices are in your neck of the woods. 😀
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 9 of 78, by user33331
How many games really need WinXP ?
Some rare soundcards with XP only drivers ?
I think all you need is Win98SE PCs(500-1500MHz) and a "modern" Win7/10 PC to play all sorts of games.
These O/Ss are unnecessary middlemen: Win95, Win2000/Me, WinXP, WinVista, Win8.
I'm always pro Win98SE.
Never liked WinXP when it was released so many games stopped working.
XP was a brick wall that stopped many games.
To me Win98SE represents the mythical golden era of PC gaming.
Golden era existed around 1993-2002.
Eternal love to 1990s large cardboard boxed games.
For example in 2003 NFS Underground 1 was released in an tiny DVD plastic cover.
Reply 10 of 78, by bloodem
user33331 wrote on 2022-05-02, 06:34:
Well, with very few exceptions, you don't really need anything except for a modern rig and some emulators, right? 😀
But that's not really the point, though, especially on the "General Old Hardware" subforum. 😉
Also, I have to disagree and I have a few very recent examples.
A month ago I started playing with my daughter Tomb Raider: Angel of Darkness (I know, not the best out of all the TR games... to put it mildly).
Since it was much easier (or so I thought), I've decided to give it a try on the modern rig, installing it from Steam, using the usual patches, dgVoodoo 2, etc.
Well, even after solving all the problems that were preventing the game from starting altogether, there are still intermittent visual glitches (black artifacts that appear and disappear randomly depending on the camera movement). Even worse, this game didn't have the best control in the world to start with, but on Win10 it's actually much worse (keys will sometimes respond with a delay or not at all).
There are also annoying things like sound adjustments only working when you first configure them, during gameplay, but once you restart the game, the sound level that was configured before will stop working until you again access the sound section. Bottom line, I've switched to the overkill XP rig I had, and played this game without a hitch!
Same thing with games like Far Cry: you can make it work on modern PCs, but there will always be annoying visual glitches (like water reflections not looking properly, not even with the so called "water reflection patches").
Then there is a game that is called "Switchball", a favorite game of mine from 2007. As much as I've tried, I could not get this game to run on Windows 10, it only works on Windows 7 or older.
And, yes, there's the whole issue regarding sound and EAX effects, which in period correct games will only work and sound properly on Windows XP.
Reply 11 of 78, by user33331
I see I have if I remember correctly:
- 200MHz PentiumPro. Geforce 5500 PCI, Win98SE. (Very speed and sound sensitive old games+ISA sound card.)
- 500MHz Duron, Voodoo 3 3500 PCI. Win98SE. (Speed sensitive old games+3dfx+PCI sound card.)
- 1133MHz Pentium 3, Geforce 5900XT AGP. Win98SE. (More demanding speed sensitive old games+PCI sound card.)
+ A lot of extra parts for similar, Socket A, Pentium 4 and such PCs.
+ A lot of Win7 PCs and one Win10 PC.
If some games don't work I go back to Win98SE computers.
Never needed WinXP. It is either Win98SE or Win7.
Modern games absolutely need Win10 because of DirectX 12's requirements.
Reply 12 of 78, by The Serpent Rider
Practically anything which has native EAX support through DirectSound3D API.
To be fair, some WIn9x games are also more convenient to run in Win NT 5.x environment.
Reply 13 of 78, by user33331
I still think EAX and THX 3D sounds are overhyped.
I have my Cambridge SoundWorks 4.1 speakers from early 2000.
Today it must be very hard to find working compatible EAX+THX multispeaker sets.
I remember EAX worked in Win98SE.
Reply 14 of 78, by Joseph_Joestar
user33331 wrote on 2022-05-02, 07:54:
I don't know about THX, but if you like playing stealth games like the Splinter Cell and the Thief series, having EAX greatly enhances the atmosphere.
Reply 15 of 78, by user33331
Yes but was EAX really limited to WinXP exclusively ?
I remember Win98SE had EAX too and working compatible drivers for EAX sound cards.
Reply 16 of 78, by Shponglefan
I still think EAX and THX 3D sounds are overhyped. I have my Cambridge SoundWorks 4.1 speakers from early 2000. Today it must be […]
Any speaker or headphone setup will work with EAX. There isn't any specific requirement to use a 4.1 setup.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 17 of 78, by user33331
Speaker types back in early 2000 were: 4.1, 5.1, 7.1 for 3D multisound.
- 4.1 is obsolete. Not manufactured for a long time.
Reply 18 of 78, by Shponglefan
user33331 wrote on 2022-05-02, 08:03:
AFAIK, this depends on the version of EAX. It started in the Windows 98 era and continued through to XP.
There are EAX games that have XP as minimum requirements (eg Battlefield 2 which supports EAX 5).
Reply 19 of 78, by Joseph_Joestar
Indeed, EAX has been around since '98. That's when the first Sound Blaster Live was introduced. You can certainly use EAX under Win98 and it works just fine.
But for playing 2004-2005 era games like Thief: Deadly Shadows and Splinter Cell: Chaos Theory, you're much better off with a WinXP machine. I'm not sure if these can even be installed on a Win98 system.
