CD drive hardware .speed when playing dos games
First post, by Aceuk
we managed to get a responce from dosbox .we tryed to install startrek next genaration A final unity.
this is what it says in the installer
THE GAME REQUIRES A DISK DRIVE CAPABLE OF MORE THAN 300KB PER SECOND TRANSFERATE RATE .
MY CD DRIVE IS A DVD-16X DVD-ROM BDV3I6E.
is my cd drive to slow .if i need to change my cd drive to a faster speed ,which cd drive should i go for?.
Reply 1 of 25, by Qbix
Rank DOSBox Author
DOSBox Author
have low cycles (say 2000) when installing the game.
Water flows down the stream
Reply 2 of 25, by Aceuk
how do u mean? i dont understand.do u mean install game in a lower installment. i installed as optermal install
Reply 3 of 25, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Lower cycles in DOSBOX. Alternative to speeding up CD is to slow down installer... The installer will not know it was slowed down, but it will think that CD is quicker...
One more thing: I hate people too lazy to write "you" properly... 😀 It is "you" not "u".
Mirek
Reply 4 of 25, by Aceuk
ithan u for that info.
i tryed to lower cycles to 500 by pressing ctrl and f12 then i tryed again in higher speed cycles it still coming up the error about a faster cd drive.and the game is dos version.
it still didnt load the game has anybody got this game and got working in dosbox?
Reply 6 of 25, by Aceuk
Sorry to say this im not that stupid . ive tryedi n windows like i said before my windows xp will not load ms dos programs when i load in windows it sayy ms dos is not suitable for windows cannot continue.please close applications
but thanks for info i guess im gonna have to buy a faster cd drive
Reply 7 of 25, by DosFreak
Sorry must be blind because I didn't see you mention that you had already tried installing in Windows.
If your cannot install in Windows and you get a "Config.NT" error or "Autoexec.NT" error then you need to read this: 16-bit subsystem error "Your system is not suitable for running 16-bit apps"
Make your games work offline
Reply 8 of 25, by Aceuk
do u need the cd to correct those problem can do it without ? but i do not have windows xp cd because my brother gave the computer to me .are u able to buy windows cd.
becausei like to fix those problems i have many games in that message error .
thank u for that information
Reply 9 of 25, by MiniMax
Rank Moderator
Moderator
No, the CD is not needed. The REPAIR folder with the good files are on you hard disk.
_________________
Reply 10 of 25, by Aceuk
i typed in run .c:\windows\repair found folder but theres nothing for me in folder to repair all i got in that folder is as follows.
autoexe. nt system
default config.nt
ntuser.dat ntuser.dat
sam sam
software secsetup
securtiy software
system.
when i open icons it just comes up with a box saying (open with)
theres no repair icon to click on to repair
Reply 12 of 25, by MiniMax
Rank Moderator
Moderator
Aceuk, there is *NO* repair program.
All you have to do, is to copy (not move!!) the AUTOEXEC.NT and the CONFIG.NT files from the repair folder to C:\WINDOWS\system32
_________________
Reply 13 of 25, by Aceuk
cool thanks minimax that solved the problem with my errors. thanks. thank u collector for the patch i downloaded that sinces i got in windosw for the old games .i have two errors this is in side the game installer it tells u what u need for the requiment to run game same as before the speed cd drive needs to be faster and now its the buffer is the problem now .i guess i cant play next genaration a final unity .
Reply 14 of 25, by Aceuk
i didnt install patch probperly .but since i put that on its picked up the speed ok of my cd drive.. its picked up the buffers (what are buffers ) erorr in installer game. hmmm grazy computers are .is there way to fix that too .im almost there too play the game.
Reply 15 of 25, by Aceuk
sorry i didnt explain well since i got the game working in windows now the startrek game has picked up the speed of my cd drive. but the patch wont install. untill i get the actuall game working installed onto my hard drive . the only thing whats proventing me doing this its picked up another error in the game installer this time its the buffers but i dont know what they are .
Reply 16 of 25, by Aceuk
where is the configsys file located on computer. iit says that i can increase the buffer to enable the game to work.
you know sinces ive enabled windows to play dos games, through my windows my computer been behaving funny like locking up.
Reply 17 of 25, by MiniMax
Rank Moderator
Moderator
There is no CONFIG.SYS - all you have is CONFIG.NT.
_________________
Reply 18 of 25, by MiniMax
Rank Moderator
Moderator
* Moving thread to the DOS forum *
_________________
Reply 19 of 25, by collector
Aceuk, in reply to your message to me, I will post it here, as others might find it useful, too.
Try copying the entire contents of the CD to a folder on your hard drive and copy the INSTALL.EXE from the patch over the original. Mount this folder as a CD-ROM in DOSBox with the -t cdrom and the -ioctl switches. Also, mount another folder as a "C:\" drive. This will allow you to install the game. Then see this thread for help on gatting it to run in DOSBox:
STTNG: A Final Unity Installation Guide for DosBox
