First post, by H.W.Necromancer
Hallo,
my effort so far is futile. I have the PowerTech MB459 board.
It is an ISA only 486 LIF socket board, I have got this corroded. I am half way to repair it - it is posting, but !no keyboard" - but any how I think I am able to finish it.
However I want to try some other CPUs and add some cache. There is a bunch of jumpers. I am able to setup the FSB clock - this I found on other web site - fortunately same for other boards with the same clocking chip.
But the propper settings for different brnads of CPUs and especailly cache is not available. /-:
There is also a version of the mobo with a voltage regulator, mine has none.
Is there any one who has the copy of the manual? Or just simply jumper descriptions?
I) My board it the same as here
https://www.clous.cz/powertech-mb459/
This fellow countryman told me he obtainede another same boards (1.2V with a voltage regulator) but all of them are with no cache.
II) another Slovak guy find out his:
MX8315PC chip is doing 25,33,40,50MHz as follows:
25MHz short-open-open
33MHz short-short-short
40MHz short-short-open
50MHz open-open-short
That is good but for more fun with the board the manual will be very helpful!
Thank you, any help is appreciated.
I hope it might help to other owners of this cute board as well.
Reply 1 of 4, by Strahssis
With some digging around in English, German, French and Dutch I managed to find this manual for you (see the attachment). The man who asked for it on a forum, said in German that it is not the same motherboard, but that he would try to use the manual anyways, but he never said afterwards if it worked for him or not. The boards do have some similar components but a different layout from the looks of it. I hope it helps!
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 2 of 4, by H.W.Necromancer
Thank you very much for such effort! I will try to get some inspiration at least. I hope messing up with the CPU type jumpers and cache size jumpers will not damge the board.
I think it it is able to post even with wrong cpu type settings, however there might be some performance issues. Thank you
Reply 3 of 4, by Solo761
Interesting how there's little info about this board...
Only thing I found was this Slovak blog post
http://brano2.blogspot.com/2017/02/rozbor-ret … oska-mb459.html
But not much info, only that maybe ECS UM4980 jumper settings would work because it has the same chipset and jumpers looks similar.
Reply 4 of 4, by H.W.Necromancer
Solo761 wrote on 2022-05-11, 06:55:
Interesting how there's little info about this board... […]
Yes, this is the Slovak post that helped me to set the FSB. I have mentioned that post above too. A Czech guy I am mailing with has got 3 of these (1.2 rev. with voltage regulator).
They have got no cache as well and CPUs are Amd DX2/66 and DX2/80. It looks these boards were quite numerous and still possible to get but PowerTech went out of business very long ago and it is pre-online period. (-: This I think why it is so badly documented today.
I am trying to reach any one who has the manual and can scan it. And I also want to use this thread to collect as much possible about this board. If I will get some settings even throughout my experiments, I will post it here.
