First post, by someguywithagateway
I recently picked up a Gateway Solo 1200 notebook from Aug. 2001. I installed a working IBM Travelstar drive into it, since it came without one. For some odd reason, the BIOS refuses to recognize the drive. I have tried two other known working drives and have the same problem. What's interesting is that if I take the hard drive out, the BIOS will recognize the CD-ROM drive as a master drive, and I can boot to a CD. However, with the hard drive installed, the BIOS won't even recognize the CD-ROM drive. The hard drive doesn't contain a jumper, since no jumper defaults to master (device 0). I'm not sure if something is failing internally, or if I would need to get a jumper and set the drive as Cable Select.
