soundblaster awe 32
First post, by scroeffie
iam building a 286 almost finished last thing to install is a soundcard
its a ct3900 awe32 i got the drivers from phils website not shure if they are correct but the install stops half way
i did run diagnose and i can hear the sound and voice testing 8bit and 16 bit
after that iam not shure what to do ,a friend told me the card wont work on a 286 because of timing ?? and the drivers wil freeze the pc when you reboot
any help please thanks i also dont understand the difrence between pnp and non pnp ? both cards need drivers ??
Reply 1 of 42, by Disruptor
No, that's wrong. As long as you can run the initialisazion tools plus AWEUTIlL.EXE you should be able to hear sound.
You need AWEUTIL because the OPL3 / FM synthesis may be routed through the AWE chip.
Just try it and write about your results.
Perhaps you have problems with the Plug and Play configuration utility CTCM on a 286.
What's with Intel ICU? What's with unisound?
Reply 2 of 42, by Gmlb256
Disruptor wrote on 2022-05-15, 13:29:
That AWE32 revision isn't PnP, but UNISOUND can be used to initialize it instead of DIAGNOSE. and AWEUTIL
Reply 3 of 42, by scroeffie
i have no idea what you guys are talking about 😀 so i need other drivers for this card to work ?
Reply 4 of 42, by Gmlb256
No. Normally you would need to initialize the AWE32 CT3900 like this in AUTOEXEC.BAT:
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET SOUND=C:\SB16
C:\SB16\DIAGNOSE /S
C:\SB16\AWEUTIL /S /R:0 /C:0
C:\SB16\MIXERSET /P /Q
Assuming that all the software are located at C:\SB16.
Reply 5 of 42, by scroeffie
so the drivers are correct but the install was never finished .so i just need to add these lines to my auto file
Reply 6 of 42, by Gmlb256
Yes, the installation should add these lines in AUTOEXEC.BAT if it was finished correctly (including some in CONFIG.SYS but those are irrelevant in many cases).
Reply 7 of 42, by scroeffie
the driver wont finish the install i think its the wrong driver ,but i tested the card in diagnose and i have sound ,config and auto files are empty just bluescreen not shure why
maybe i need to delete eveything and start over
Reply 8 of 42, by scroeffie
i friend says its not possible to install this card directly because of the drivers on a 286 ,he says i need to install it first on a 386-486 than put it back in the 286
Reply 9 of 42, by Gmlb256
I think that you are better off with UNISOUND to initialize that sound card on a 286 computer.
If you decided to download it and transfer the COM executable that is inside the zip file into the root of the C drive on the 286 computer, add the following lines into AUTOEXEC.BAT:
UNISOUND /CS
It is much simpler and I added the /CS command line switch because your AWE32 isn't a PnP card.
Reply 12 of 42, by scroeffie
iam going to try the unidrivers
if that wont work than iam giving up
Reply 13 of 42, by scroeffie
nothing is happening i deleted dos and resintalled dos than the com file buts its a com file its does nothing ?
Reply 14 of 42, by dormcat
scroeffie wrote on 2022-05-15, 18:03:
May I ask
  1. Have you ever used MS-DOS before? Do you know how AUTOEXEC.BAT and CONFIG.SYS work?
  2. What is your native language?
  3. How old are you?
You've been active on VOGONS longer that I have. Four years would be more than enough to get a hold on some basic MS-DOS knowledge.
Reply 15 of 42, by Gmlb256
Only remove both 1 and 2 from each line in AUTOEXEC.BAT. 🤦
dormcat wrote on 2022-05-15, 18:09:
May I ask […]
May I ask
  3. How old are you?
weedeewee and I had some trouble explaining the details to him on a different thread.
Reply 16 of 42, by scroeffie
yes i have been using ms dos sins i was a kid ,but i forget fast and iam autistic and have dislexia ,iam 40
native language is dutch ,iam not good at reading and when i read i need time to process what i read 😀 if that makes sense
wil try again to install it but not shure how to install a com file ? where is the exe file ?
Reply 17 of 42, by dormcat
scroeffie wrote on 2022-05-15, 18:18:
Okay, I understand you have difficulties, but you have to know the basics of how MS-DOS and its key system files work. You "deleted dos and resintalled dos" but that wouldn't help.
And I wouldn't recommend installing AWE32 on a 286. System requirements provided by Creative Labs required 486 with 4MB RAM minimum; while it's possible to install the card on an older system, it would be similar to testing the minimal memory requirement of Windows:
The attachment tdnc.jpg is no longer available
Taken from https://www.youtube.com/watch?v=i9VFikWw44g
Reply 18 of 42, by scroeffie
stil no sound how do install the com file ? what am i doing wrong
Reply 19 of 42, by dormcat
scroeffie wrote on 2022-05-15, 18:58:
You have to edit your existing AUTOEXEC.BAT file, not creating a new AUTOEXEC without .BAT extension.
