First post, by Strahssis
Hi everyone,
I just made a backup of the original hard disk of a Compaq Contura 420CX with all the original drivers and software from Compaq. All personal, sensitive data has been removed, but please be respectful if you find anything I might have missed. Other than that the image is completely authentic from 2003, when the laptop was last used. I wanted to put it here on Vogons just in case anyone is looking for the original files or is just curious. Have fun! https://archive.org/details/compaq-contura-420-cx-backup
All the best,
Miko, Strahssis
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 1 of 12, by Joakim
That's nice of you.
Is it a good retro gaming laptop? Good screen? Any sound card?
Reply 2 of 12, by Strahssis
Joakim wrote on 2022-05-15, 19:20:
It has a 10.4 inch 640x480 active matrix screen, so basically de creme de la creme for retro gaming. Sadly it doesn't have a sound card, so I use an external MIDI device or a Covox Speech Thing clone to get sound out of it. It is very picky with CF-cards, so I'd recommend anyone buying or having this laptop to use an SD-card or just the original hard drive. The build quality and serviceability is also excellent, and it doesn't have barrel battery of doom. It comes with a 486DX4-75 with 8MB of RAM, which I upgraded to 16MB. All around I really like this laptop. 😀
Reply 3 of 12, by Joakim
Sounds almost perfect. Maybe it can utilize of of those PCMCIA sound cards.
Reply 4 of 12, by Strahssis
It could, but sadly I don't have one of those and the 9x-compatible ones are pretty rare. The PCMCIA sound cards you usually see for sale are for Windows 2000 or XP and up. I bet a sound card like that would make it the perfect portable retro gaming device.
Reply 5 of 12, by porconocco
Thanks for sharing. Trying to burn it into CD card. What software did you use to create it, and what can be user to burn it to a disk? Balena complains that the iso image is not bootable and when I burn it anyway, no partitions are seen on it.
Reply 6 of 12, by porconocco
* Sorry, I meant trying to burn it to CF card
Reply 7 of 12, by wierd_w
If it's a hard disk image, it's not meant to be booted that way. (Cdrom)
I'd have to look more closely, but hard disk images are usually raw disk images, with a partition table and all that. Aside from 'hybrid iso' shenanigans used by linux live cds, these cannot be written to a cdrom as it is not an iso9660 filesystem.
Since this is for a pre-lba type hard disk, the raw image might not work if put onto a cf card with Etcher.
Let me examine this image file and get back to you.
Reply 8 of 12, by wierd_w
Ok, file *is* an ISO image, and should be written to a CDR, not directly to a CF card.
I dont think it is bootable. It looks like this is a bland filesystem backup, not a proper disk image of a virgin/stock system.
To get this working for you:
Create a minimal boot floppy with fdisk, format, xcopy, mscdex, and cdrom drivers.
Partition, format (with /s flag!), the CF card in the system.
Change directory to the cdrom.
Use xcopy to copy the contents to the C: drive with the 'even empty subfolders' option.
Try booting from the CF, and pray.
Please note that the language regionalization of this dump is GERMAN.
It looks like dos 6.22
Reply 9 of 12, by Strahssis
Hi all, It has been a long time since I made this backup, so I'm not entirely sure which software I used and how. Since it is an ISO file, I probably used PowerISO. If I remember correctly, the image wasn't bootable.
Reply 10 of 12, by porconocco
Thanks! I got myself a Compaq Contura 420C in a very spectacular condition, but with dead HDD. Trying to revive it. Got the recovery floppy images from internet archive, now waiting for a USB floppy drive to arrive, because I don't have anything to write those floppys with. The plan to create a bootable partition with recovery floppys and then copy files from this iso there seems reasonable.
Reply 11 of 12, by Strahssis
Sounds like a solid plan. The Contura is a great laptop, so I expect you will get a lot of enjoyment out of it. 🙂
Reply 12 of 12, by porconocco
Ok, I finally succeeded. Found the working pair of setup/diag floppy creation tools, managed to install Win95 on the 1GB Compact Flash card. Boots like a charm. Then I copied a full disk image, supposedly, bootable: https://archive.org/details/compaq-contura-420c-win95-clean also attached there a setup/diag diskettes images.
Now I'll have to do something with the screen which has a huge light spot in the middle, looks like an early stage vinegar syndrome 😅
