First post, by GabrielKnight123
I got a MB-1500PCT-A Rev.2 motherboard as pictured below I can't find a manual for the jumpers, the jumpers are printed on the pcb but the trace test points are blocking the writing for some jumpers
Reply 1 of 1, by Repo Man11
Hopefully the jumper setting for the 1500TIC will be some help, they don't show a PCT: https://web.archive.org/web/20001005212820/ht … xTIC_Manual.htm
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
