First post, by Daninthemix
I get this error when trying to run Lomax with DgVoodoo.
Doesn't seem to matter which DgVoodoo settings I modify.
Reply 2 of 4, by Daninthemix
The game works through DxWnd. If I add DgVoodoo that's when I get the error. Or if I remove DxWnd and only have DgVoodoo, I get the error. DgVoodoo must be activating because I ALSO add Reshade and I can see from the Reshade log it is initialising. Meaning DgVoodoo did hook, and then got hooked by Reshade (DgVoodoo as DDraw.dll, Reshade as dxgi.dll).
Reply 3 of 4, by Dege
But the debug layer would be useful to see if it reports any problem.
Anyway, did you copy D3DImm.dll into the game folder? Because I get the same error message if it's not there... (and it must be the same version as DDraw.dll of course)
Reply 4 of 4, by Daninthemix
I did not, but I have now. That gets rid of the error. Now the game just crashes. Hmm.
EDIT: nope that fixed it! Thankyou!
