First post, by aureal
Just leaving this here so nobody else falls into the predicament I was in.
If you are looking for the bios files to flash your Shuttle system grab them from here: https://download.shuttle.eu/Archive_2004/
In my case I was looking for the bios to update my sn41g2 and the bios files at https://global.shuttle.com/products/productsD … ctId=487&osId=6 contain the bios only and not the flasher anywhere. If I have to go and hunt down the flasher myself I have no idea if its compatible or malware infested because using the exact same flasher shuttle uses on their motherboard, on their website is the safest.
It's dumb how they put the bios file up without the flasher anywhere. It's not a motherboard which has built-in bios flashing either.
