First post, by TrashPanda
Anyone have any suggestions on how to remove this shit without damaging the underlying plastic ?
One of my older laptops has decided that now is when its surface coating is going to turn into a horrible sticky mess, its in its early stages so I am hoping it'll be easy to clean it up.
Going to give some WD40 a shot and see if it'll move this stuff or if it just makes it worse.
Reply 1 of 14, by paradigital
You’ll probably end up needing something stronger than Isopropyl or WD40. You need to remove the entire coating. Methylated spirit or petrol tends to work OK for this but you are at risk of softening the underlying plastic.
Short answer is that there isn’t really a quick and safe way to do this, it’s either quick and risky or slow and safe.
Reply 2 of 14, by TrashPanda
paradigital wrote on 2022-05-30, 08:48:
Willing to go slow and safe here as the laptop itself is in excellent condition aside from the palm rest coating degrading, ill try Metho if the WD40/Iso doesnt move it, might try some high grade goo remover too.
Reply 4 of 14, by chrismes
I had to remove the coating from my Thinkpad 560X, but it was very sticky and pretty far gone. I ended up scraping it off with a plastic card (like a credit card) and took care of the rest with isopropyl alcohol. It was a pretty slow process, but it looks fine now. No scratches and no damage from the alcohol.
Reply 5 of 14, by TrashPanda
Not even sure what possessed them to use this type of coating, it was horrible to start with and its even worse years later.
Fuck the guy who developed this coating.
Reply 6 of 14, by maxtherabbit
Fake rubber is just god awful
Reply 7 of 14, by Nexxen
I use chanteclair degreaser, apply wait wipe. Reapply if needed.
No harsh chemicals. At least it always worked for me.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 8 of 14, by cyclone3d
TrashPanda wrote on 2022-05-30, 16:02:
And it is still in use on new products.
The person that invented it and the companies that still use it, need to be forced to clean it off ever single device that it is used on... With nothing more than a rag and water.... There needs to be a special level of Hell where that is what the punishment is.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 14, by Rikintosh
Forget oily solutions, there are 1001 people talking about using wd40 or other crap, this will only "fix" it at best, but overall, you'll end up with a disgusting, greasy rubber. This stuff deteriorates chemically, and needs to be completely removed. I've had a lot of experience with Thinkpads, and even newer lappies like the Asus G73jh. This was one of the biggest misfortunes invented in computing.
You need to use a solvent that doesn't attack plastic, just rubber. Isopropyl alcohol will remove, but needs millions of "rubs". I recommend using Ethanol because it is faster and less aggressive (use gloves). In my country, ethanol is a very common fuel for automobiles, and I usually buy it at the gas station, I don't know how it is in the United States, maybe you can find it in a chemical or agricultural product store. Gasoline and even diesel will also "dissolve" it but I would only recommend it as a last resort as they will attack the plastic underneath the rubber.
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 10 of 14, by cyclone3d
I think race fuel in the US is really the only easy way to get 100% ethanol. The normal stuff here is 85% ethanol, 15% gasoline/petrol.
I've tried a ton of different things and th best I've found so far is the lemon essential oil. Think goo-gone but about 100 times as effective.
That is, if you get the good stuff. The crap that Walmart sells I am sure is already diluted down as it is very weak.
YMF7x4 Guide
Reply 11 of 14, by maxtherabbit
Rikintosh wrote on 2022-05-30, 19:45:
The stuff is not actually rubber. It's a synthetic
Reply 12 of 14, by TrashPanda
I can get Methylated Spirits easy enough which is just denatured Ethanol but getting Ethanol itself might be difficult as its not sold here in its denatured form outside of chemical suppliers. I think I will try a two pronged approach with both Methylated Spirits and Essential Lemon Oil following it to clean up the surface after.
Reply 13 of 14, by TrashPanda
maxtherabbit wrote on 2022-05-30, 22:04:
I'm not worried about what it is just how to exterminate it from my Thinkpad without damaging the plastic under it.
Reply 14 of 14, by Rikintosh
I have never used lemon essential oil to remove rubber, but I did use it once to remove a strong damp/mold odor from a Powerbook G3 that was completely contaminated. It worked very well, and to this day it has a slight lemon scent.
