A smol K6-II+ /Voodoo build
First post, by PcBytes
As the title says, it's a rather small K6-II+ build that I've done out of some parts I've been keeping around for some time.
Specs first:
MB - Luckytech P5MVP3
RAM - 384MB
Case - Cyber/CSX-917D
PSU - custom-rebuilt ASTI LC-200C
ODD - ASUS DRW-1814BL
HDD - Maxtor Fireball III 40GB
GPU - 3dfx Voodoo 3 3000 16MB
LAN - RTL8139C PCI
USB - NEC USB2.0
Sound - Yamaha YMF-719 OPL3-SAx ISA
OS- Win98SE
Finally, pics below.
Reply 3 of 52, by bloodem
Very nice build, congrats! 😀
Ydee wrote on 2022-06-06, 12:06:
In my case, the K6-2 (non-plus) and card with USB 2.0 and NEC chip caused a noticeable drop in performance on the board with Aladdin V. I had to replace it with Opti USB 1.1.
I was about to write that too. It doesn't matter the CPU (plus or non-plus), the performance hit can be pretty extreme.
So, two things to improve performance:
- get rid of the USB 2.0 card
- go with 128 MB of RAM instead of 384 (with a K6-2+, performance is degraded by ~5 - 10% when using more than 128 MB). And, realistically, 128MB is more than enough for a K6-2/3(+) build.
As for the PSU, not sure what "custom-rebuilt" means, but I would seriously consider going with a modern PSU + AT adapter. Those old PSUs were already very poorly designed + cheaply built, so after 20+ years they're just ticking timebombs waiting to go "KABOOM, RICO, KABOOM!". And when they do, other components (like the MB) are part of the usual collateral damage. 😀
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 4 of 52, by PcBytes
bloodem wrote on 2022-06-06, 12:12:
Electrically it's an ESSUN branded PSU inside, not the original ASTI, which was much more crappier.
What I have done to it:
-replace all big caps - main caps, entire secondary side also replaced, all with newer caps - Rubycon mostly, though I had to resort to using some slightly less than ideal "Yang Chun" (Saturn logo) 470uF 16v caps in about two places because of the capacitor placement being a bit of an issue.
-upgrade rectifiers
-oiled the fan using bicycle oil -
-replaced most of the crummy molex wiring with new wires from two discarded Premier LC-C400ATX units
-upgraded secondary sillicon from the puny 8A on 12v and 16A on 5v - 5v now has 20A rectifier (would have gone with 30, but the silkscreen on the mobo and the holes don't allow for it.), and 12v has a 12A fast recovery rectifier.
So all in all, while not very substantial upgrades, I guess I have given it at least 10-15 more years worth of service. The only things I haven't done is upgrade the AC filtering side - I am out of safety approved Y capacitors (the disc kind of caps that go on the AC filtering) and I'm a bit confused as to how the common mode choke is currently wired - I want to change that one primarily because it's literally a candy coloured common mode choke that I doubt is very efficent. The only thing that's been changed was replacing the polypropylene film capacitor that was used as a X2 capacitor with an ACTUAL yellow X2 cap, and nothing else besides that.
This one was in a batch of about three PSUs that I had to fix. The third one still awaits parts, but the other two (this one and a Premier LC-8500BTX) I legitimately have spent about 6 hours or so (give or take) to completely make them decent units, especially the LC-8500BTX.
Reply 5 of 52, by Jasin Natael
Mine too. I had to revert to locating a header and using the built in USB 1.1
Reply 6 of 52, by PcBytes
Strange, maybe it was a issue with Aladdin V chipset? Mine runs on VIA MVP3 and I never had issues with the NEC USB 2.0 card dropping performance.
Reply 7 of 52, by bloodem
PcBytes wrote on 2022-06-06, 13:19:
No, the issues I'm referring to happened to me on multiple VIA MVP3 boards.
What benchmark numbers are you getting (GLQuake, Quake 2, Quake 2 software mode)?
Reply 8 of 52, by PcBytes
I haven't tried benchmarking it yet (I'm not usually the person to run benchmarks and all that, just build and have fun playing games on it) , but so far I don't see any slowdowns in the 3D games (Monster Truck Madness 2, Tank Racer, NFS IV and Porsche 2000 are a few that come to mind, but from what I recall I have a lot more installed on it) I've been playing.
That, and I absolutely and postiviely cannot ditch the NEC card. USB1.1 is absolutely painful to use to transfer, especially when I need to copy large amounts of files (e.g Windows 98 and ME CDs, and generally anything that's in ISO/MDF format) from a pendrive to the HDD.
Reply 9 of 52, by bloodem
PcBytes wrote on 2022-06-06, 13:49:
Ah, OK, it makes sense then. 😁 Still funny that you consider NFS Porsche playable on a SS7 build, though.
I mean, I'm not very picky about framerates in general, but playing NFS Porsche on a SS7 platform is a pain for me (even on a VERY overclocked K6-3+ build).
Reply 10 of 52, by Jasin Natael
Very nice build, congrats! :-) […]
Good advice on the RAM. Nothing that will run acceptably on a SS7 should realistically use more than 128MB. Phis's test were hit and miss with the caching performance impact but I did notice about 5% better performance in most games when I removed the second 128MB stick in my PC. Mine is a crappy PC Chips M571 though, so the SiS chipset might show some differences from a more mainstream chipset.
Reply 11 of 52, by Ydee
I haven't tried benchmarking it yet (I'm not usually the person to run benchmarks and all that, just build and have fun playing games on it) ...
If I remember correctly, in Sandra the reduced memory throughput was about 1/3 and in 3DM99 the score was about 800 compared to about 1200 on the same configuration, with only different USB cards. That was worth considering.
I bought the board (Gigabyte GA-5AA) without a USB bracket, hence the use of a PCI USB controller. The USB 1.1 speed is really not stunning, but I upload games and most apps to HDDs from DVD/CD-ROM, so I only have an occasional mouse or flash drive connected via USB.
Reply 12 of 52, by PcBytes
bloodem wrote on 2022-06-06, 14:08:
Mine runs fine, haven't recorded framerate but it looked smooth enough in my experience. Then again, I didn't run it very high in quality - 800x600x16 (the max that the V3 supports AFAIK), rest of the settings were done by the game by default.
I've run it on a Matrox G200 as well and it was playable. The only card I've seen it literally become a slideshow mess was the original ATI Rage IIc AGP and Rage Pro Turbo based cards (including the Rage Pro AIW.), otherwise it ran playable on about any card I've had that wasn't based on Rage.
Reply 13 of 52, by Jasin Natael
PcBytes wrote on 2022-06-06, 14:43:
Voodoo 3 can do higher resolutions than a Voodoo 2 (even in SLI) but there are some games that will limit the resolution, I think due to the renderer, Quake II for example.
Reply 14 of 52, by PcBytes
The max it can go, at least on my Samsung 32" TV I'm using, is 1024x768. Won't let me any higher than that on either 9x or 2000.
Reply 15 of 52, by ynopot
I'm not impressed ))
Instead of RTL8139 try something like 3COM905-TX. This will help offload the processor
CPU - K6-2+ 450ACZ @ 550MHz
MB - Soltek SL-54U5
RAM - 128 Mb SDRAM PC100 (2x64Mb) 2-2-2-5 / 4 way bank interleave
Case - no name
PSU - no name
ODD - LG CD-RW CED-8080B (not in the photo / photo before upgrade)
HDD - WD 40GB (not in the photo / photo before upgrade)
GPU - GF2MX400 32MB 128bit AGP 1X (not in the photo / photo before upgrade)
LAN - 3COM905-TX (not in the photo / photo before upgrade)
USB - on board (not in the photo / photo before upgrade)
SB - Creative AWE64
OS- Win98SE
240.08 KiB
105.45 KiB
115.36 KiB
103.81 KiB
106 KiB
Reply 16 of 52, by Jasin Natael
ynopot wrote on 2022-06-06, 18:03:
I'm not impressed )) […]
MB - Soltek SL-54U5
Case - no name
PSU - no name
SB - Creative AWE64
OS- Win98SE
Not really apples to apples as the video card is entirely different.
But that is for sure a nice performing system.
Reply 17 of 52, by ynopot
Jasin Natael wrote on 2022-06-06, 18:09:
Before that was ATI Rage 128 16Mb AGP
Reply 18 of 52, by PcBytes
I've had the 3C905-TX in a few previous builds (not necessarily listed here).
It's absolutely atrocious in download speeds compared to any other NIC card I've tried - even an Intel Pro 100 and the current RTL8139c download faster than that 3com.
Reply 19 of 52, by ynopot
PcBytes wrote on 2022-06-06, 19:41:
Before that, I had RTL8139 in this system. This is a software card. When the download speed from FTP reached 4 Mb / s, it slowed down my system. 3C905-TX is a hardware card with its own processor that helped me achieve better performance
