First post, by magestic
I have this lockup problem only after loading up windows 3.11 a second time after booting to dos 6.22. For example, after loading windows, exit, then windows again. As soon as I try to load windows again, I get a network card error and the system freezes. I have to do a cold boot if I want to load windows …..
The actual error is: Your network adapter MS$ELNK3 is not working properly. You may need to set it up again. For more information, see “Troubleshooting” in your “Workgroup Add-On Users Guide.”
MEM TEST reports no errors for my RAM.
My hardware
Gateway 2000 Intel 440 motherboard + Pentium II 233MHZ CPU + 96MB PC100 memory
1996 3COM ETHERLINK III 3C509B-TPO 16 BIT ISA ETHERNET
Creative Labs CT2940 Sound Blaster SB 16 PNP 16-Bit ISA Card
ATI Rage XL 8MB PCI VGA Desktop PC Video Graphics Card
What can I do to try to troubleshoot this Hardware problem? Maybe my network card is flaky? It works good on a cold boot.
