First post, by johnyept
I currently have an ASUS P4S8X-X (Intel P4) in my RETRO-W98 machine because the ECS N2U400-A (Athlon XP) doesn't boot, probably due to board corrosion since the caps look OK but the board metal parts show oxidation due to bad storage.
I found an ASUS A7N8X-X for sale with CPU and 2x128MB. It's a recycling store for charity and it's selling it for 15€/$. It seems very similar to the ECS N2U400-A, but it doesn't have the 4pin connector, and the chipset is the nForce2-400 (single channel) instead of the nForce2-400 Ultra (dual channel). Should I go for this board instead of the Intel one? Phil did make a video about the ECS N2U400-A as one of the best boards for Windows 98, but he did mention that having a 4pin connector was one of the positive points, which the ASUS doesn't have.
RETRO-W98/2K: MSI MS-6309 v1.0, P3 1Ghz, 3x256MB, GF5600 128MB AGP, VD2 PCI, RTL8139D PCI, TB400-2541 PCI, ESS1868F ISA, 160GB IDE
RETRO-WXP/7: ASUS P5KPL-AM EPU, XEON E5450 3Ghz, 2x2GB, GTS 450 1GB PCI-E, 120GB SSD, 1TB sATA
