First post, by kikendo
Just got a machine with this motherboard. I know, they're terrible! But I don't care, I just wanna get this running.
The manual mentions a CD but I don't have it. I cannot find it in vogonsdrivers.
Anybody got a copy of it? I have the system running a Windows ME and I want to refresh it to 98SE but I would need drivers for all this stuff. Manual mentions IDE bus, USB, video, sound, LAN and modem drivers, plus an application for configuring the sound hardware.
This is what Windows ME reports, maybe it's helpful in finding loose drivers:
90.33 KiB
Alternatively, any way of extracting the drivers already present in ME?
[edit] I downloaded this but does not seem to contain what I want: http://vogonsdrivers.com/getfile.php?fileid=1 … menustate=31,29
[edit 2] this is not the right disc either: https://archive.org/details/PCChipsMotherboardCD2_3
Reply 1 of 6, by Repo Man11
It seems that board uses the SiS 620/5595 chipset. PCChips old download page has a LAN driver: https://web.archive.org/web/20061020193316fw_ … d-bios.asp#M741
If you want to use the onboard sound or graphics (assuming it has either) you should be able to find them on this page: https://web.archive.org/web/20061020193306fw_ … 2.asp#socket478
Reply 2 of 6, by kikendo
Repo Man11 wrote on 2022-06-14, 04:26:
They don't have the exact same versions I have, that I posted above. And I am not sure any of these would support what I do have.
The direct page link to downloads is here: https://web.archive.org/web/20061020193255fw_ … port-driver.asp
Just to put it in text, the gear I have is:
- Display: SiS 620 (available at above-linked page)
- IDE: SiS 5513 Dual PCI IDE Controller
- LAN: DAVICOM 9102 PCI (available at above-linked page)
- Sound: CMI 8338/C3DX PCI (Driver for CMI 8738 seems to support it)
- USB: SiS 7001
So I am missing those other three.
Reply 4 of 6, by Repo Man11
With my PCChips M930 (SiS 645) when I install Win98 I found that I need the SiS IDE driver (the default one works, but the port does have better bandwidth with the SiS driver), and there's an AGP driver that I install, though I've not done a performance check of before/after to see if it nets me any performance gain over the default driver that 98 installs. I found a driver for the LAN, but I'm not using it, and I found that having it enabled with the driver installed causes a noticeable delay in getting to the desktop as it apparently searches for a network. I found a driver for the onboard sound, but only one channel works so I disabled it and use a sound card instead. For USB I use the NUSB driver that you can find linked here, it works very well: Generic Win98SE Installation & Setup Guide
Reply 5 of 6, by kikendo
Repo Man11 wrote on 2022-06-14, 16:41:
Welp this is why I would like to find the original CD delivered with this board, but it seems it's nowhere to be found.
I'm going to image the current ME install and try to install 98SE from scratch and see how these frankenstein drivers I found work.
Reply 6 of 6, by dionb
That's not a driver issue, but normal Win98 behaviour. You'd get this with any NIC.
