.info wrote on 2022-06-23, 01:31:
I tried CTU, it does not have an option to disable L3.  There a couple additional slow down settings which allowed me to get a bit slower that setmul, still in the range of a 486-33.  I still would like a way to disable the L3, this is otherwise a pretty nice rig,
If you buy a LIF socket and a interstitial socket you can interrupt a few different pins before they make it to the motherboard. I suspect you may be able to disable cache by interrupting brdy, brdyc,  or ads, adsc there are also a few other pins of interest. Those were the pins of interest on the tillamook mods that re enabled cache on them. But I’d have to look up what was going on there again to be of more help. One sec, I’ll pull up the datasheet.
If we figure this out, I can incorporate it into the tweaker so it can be switched on and off
Alternatively you could unsolder these pins from a black pentium mmx one by one and record the results
Edit:
https://datasheet.octopart.com/PENTIUM-MMX-23 … eet-7279168.pdf
Start on page 15
The obvious pin is the cache pin but reading it I don’t think it works the way we want it to.
https://www.amd.com/system/files/TechDocs/23542a.pdf
Here is the 2+ data sheet
