First post, by beatbiku
Hi everyone, and first of all sorry by my english !
I recently purchased an HP T5710 with a 2GB flash memory module. I followed many tutorials in the internet but i'm getting stuck in the process of partitioning.
The main problem is that i get to fdisk and it detects the boot usb as the primary fixed disk, and the hard drive as fixed disk 2. This means that i can not switch the hard drive to 1 (fdisk does not allow that as far as I know). I verified that the jumper in the module is set to 3-4 (master), so i hope this is ok.
I tried to start via USB DOS boot, copy win98 folder to hard drive, and i could start the windows setup process, but it shows error su-0409 when starting to copy files. ("Windows was unable to update your files...because enabled antivirus...blah blah) . I tried for hours but i couldn't go any further.
Maybe one of you have any recomendations in this scenario? Thanks in advance!
