First post, by brettp11
Hi!
I’ve got this great 486 retro system and the motherboard unfortunately has a barrel type CMOS battery. Everything still works perfectly. It also has a jumper for an EXTERNAL battery.
I’ve attached pictures. It looks like it will be difficult to cut it off but I have limited experience so wanted to get everyone’s opinion. Also I have ZERO soldering experience and would be afraid of ruining the board if I tried to de-solder it.
Any advice? Has anyone ever used some sort of glue or epoxy to just cover / encapsulate the battery and mitigate a leak?
Thank you!
