First post, by haker120
I have mobo ASUS TX97-XE (V3.x) and I cannot find USB drivers for my mobo, I found USB flash drivers but not one for hardware itself, any help appreciated. 😀
Reply 1 of 4, by zapbuzz
i found bios and intel inf for that board have you installed the intel inf installer? maybe it has your usb?
have attached correct intel inf in sfx for you i haven't seen a separate usb.
If you already have it installed disregard this but still haven't found any separate usb driver so this might be it.
the bios updates available include enabling and disabling usb IRQ so i think it'd be wise to look at your bios features to see and enable it
if not already.
    intelinf.exe
    2.95 MiB
    23 downloads
    intel inf win95 scanned with microsoft windows 11 and avira
Reply 4 of 4, by haker120
Ok, I guess it looks like missing component but it says, under yellow question mark, that this device is working properly with IRQ4. My other issue is DOOM and DOOM2 under DOS Mode (window) hang with info about mouse something and only hard reset helps, DOOM95 works but... without MIDI it's not real DOOM.
EDIT: For some reason compatible USB device isn't detected, any USBs are not.
EDIT2: I fixed DOOM and DOOM2 issue by installing Win95OSR2.1 again but USB issue persists...
EDIT3: USB fixed as well, this is odd, yellow question mark, and installing XUSBSUPP.ZIP (not even for my OS' language) did nothing, 95 is dumb, first remove support -> reboot -> remove all ? devices (fortunately only one) install USB support and then OS condescendingly will accept new device as device, not ?, darn. Thanks everyone for help! 😁
