First post, by Kahenraz
- l33t
During testing, I found that it was possible to boot FreeDOS from a logical partition without the need for a bootloader on that partition, or for it to be "active". I formatted a large 400GB logical partition at the end of a disk as FAT32 from a Linux live CD and then copied over a FreeDOS installation as a bunch of files. I was then able to successfully boot by chainloading KERNEL.SYS via the GRUB4DOS bootloader.
This is particularly useful as a means to save on a primary partition when configuring a system to boot multiple operating systems. This has the added benefit of the partition being able to remain visible, with its contents accessible from other operating systems such as Windows 98.
