First post, by Guest
I have TFT monitor, whose default resolution is 1280 x 1024 pixels. Using other resolutions, the image is bad.
If the original resolution of DOS game is f.ex 320 x 200 pixels, is it possible to run it in 3x (960 x 600 pixels) or 4x (1280 x 800 pixels) window holding full screen resolution still at 1280 x 1024.
In the config file there's no possible to give parameter scalervalue normal3xor normal4x.
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
set output=overlay
and use hwscale=3 or hwscale=4
Water flows down the stream
Reply 2 of 7, by red_avatar
A problem with this: it "softens" the edges of the graphics, something I'd rather not have. Is there a way to just increase the size of the window without having fuzzy edges?
http://www.stevieparmentier.com/edges.jpg
This is from Leisure Suit Larry 3 and as you can see, it's quite obvious. I prefer the real pixel look.
scaler=normal2x is a good straight pixel-resize but it only doubles, while I'd like to have it 3x or 4x for my LCD screen. 2x is just too small.
Reply 3 of 7, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
What about output=openglnb ...
This is OpenGL without filtering...
Mirek
Reply 5 of 7, by red_avatar
Thanks, been using your version with D3D. Does the D3D mode use more CPU power than normal2X surface ?
Reply 6 of 7, by gulikoza
Actually it should be less since the pixels are stretched by hardware...
Reply 7 of 7, by red_avatar
Good - it works fine so far, very sharp clean pixels. Good job.
