First post, by elyosh
Hi, I'm trying to verify a quirk in the OPL3 datasheet regarding the timers period (it is documented as being tov[ms] = (255-N)*0.08, versus tov[ms] = (256-N)*0.08 for all other OPL), for that I need the help of OPL sound card owners to run a quick test program under DOS on their hardware.
Testing on any (real) OPL would also be helpful for comparison, OPL2/OPL3/OPL3-L..
The program is available here: https://bobox.elyosh.org/open/OPLPROBE.EXE or as a bootable floppy image here: https://bobox.elyosh.org/open/OPLPROBE.IMG
It will output something like this which you can then provide me : oplproben.png
Thanks a lot !
Reply 1 of 14, by DerBaum
I will test some cards later. I have real opl 2 /3 / L and clones .
Why do you need this data? Want to make a program, a game or hardware? Im just curious.
FCKGW-RHQQ2
Reply 2 of 14, by elyosh
DerBaum wrote on 2022-07-31, 11:53:
That would be really helpful, thanks.
I'm working on the 86Box emulator, and this would allow to accurately emulate the real hardware's behavior.
Reply 3 of 14, by Tiido
I posted 5x results into the attachments. I have no OPL2 to play with for the time being. Timer 1 with 255 is highly variable with its result on my test machine (1.4GHz PIII machine with VIA chipset)
Anyway for completeness sake :
The timer circuitry runs off YM's sample rate which for
OPL2 is MCLK / 72 = 3579545 / 72 = 49715.90277....Hz (20.11428... µs)
OPL3 has 4x higher MCLK but it is divided down by 4x so end result is same as OPL2
OPL3L is a little trickier, MCLK there is 33868800Hz and internal sample rate slightly different from OPL2/3 : 33868800 / 684 = 49515.78947...Hz (20.19557...µs), which is then decimated into standard 44100Hz rate (33868800 / 768) for final audio output.
OPL2/3 Timer 1 counts every 4x YM output cycles (80.457153...µs), Timer 2 every 16x YM output cycles (321.82861...µs).
OPL3L Timer 1 has (80.78231...µs), Timer 2 every 16x YM output cycles (323.12925...µs).
I'm pretty sure the 255 is a typo, though it is difficult to gauge from the results I got as 255 result on Timer 1 is all over the place.
Timer 1 period is supposed to be (72 * 4) * (256 - T1val) clock cycles
Timer 2 period is (72 * 16) * (256 - T2val) clock cycles
Timer value of 0 should be longest possible count and using that will determine if 255/256 difference is actually there, if it is 255, 0 will show much different result. (it is not something I have personally tested) so perhaps you should make a test with 0 value aswell.
Reply 4 of 14, by elyosh
Tiido wrote on 2022-07-31, 13:55:
I posted 5x results into the attachments. I have no OPL2 to play with for the time being. Timer 1 with 255 is highly variable wi […]
Thanks for testing ! My measuring of the time is only accurate to around 10-20 µs, so that would account for the variability you see with timer 1 at 255.
I agree with you that the "255" in the OPL3 datasheet is most likely a typo.
What is much stranger to me is your results with "YMF278B 1.jpg " where you basically get the same period no matter what.. is that the same sound card as in "YMF278B 2.jpg" or a different one ?
Reply 5 of 14, by DerBaum
YAMAHA OPL2 YM3812-F (Aztech (I38-MMSD801) Sound Galaxy NX II)
The attachment 2022-07-31 16.05.56.jpg is no longer available
YAMAHA OPL3L YMF289B (Aztech (I38-SN96103) MM Pro IIB-3D)
The attachment 2022-07-31 16.09.21.jpg is no longer available
CRYSTAL OPL3L (clone) CS4289-KQ (Unknown Manufacturer CS32-3DI)
The attachment 2022-07-31 16.35.58.jpg is no longer available
System Pentium 1 200MMX.
FCKGW-RHQQ2
Reply 6 of 14, by Tiido
elyosh wrote on 2022-07-31, 14:07:
It is a different sound card, and yeah, it was weird to see that happen. I'm not sure why it was so either, since all tests were done in pure DOS with exact same environment so maybe the card has some hidden fault on it.
Reply 7 of 14, by grommit2007
Quite interesting findings. Would anyone be able to run these tests on cards with OPL clones (like Crystal FM, ESFM, and CQM for example)?
Reply 8 of 14, by elyosh
DerBaum wrote on 2022-07-31, 14:42:
YAMAHA OPL2 YM3812-F (Aztech (I38-MMSD801) Sound Galaxy NX II) 2022-07-31 16.05.56.jpg […]
Thank you for testing. It's interesting to see that the only card that actually implemented the typo from the OPL3 datasheet that causes the timer to expire immediately if it is set to 255 is your Crystal CS4289 clone !
Reply 9 of 14, by DerBaum
elyosh wrote on 2022-07-31, 15:55:
If somebody wants to see the card...
The attachment 2022-07-31 16.36.47.jpg is no longer available
on the top left you see the "CS4289-KQ" OPL3L clone. The Chip right next to it on the right side "4333-KS" is the DAC.
(The unpopulated pads below the chips are for a real YMF262 and YAC512.)
FCKGW-RHQQ2
Reply 10 of 14, by georgel
What does OPLProbe use as a timing reference under DOS?
Reply 13 of 14, by grommit2007
Can anyone run this test on a CMI8738 card?
I am curious as to what the OPL clone in this identifies as.
Reply 14 of 14, by Stretch
grommit2007 wrote on 2025-06-08, 14:06:
Here is the output from the M-Audio DiO 2448 sound card, which has the CMI8738 chip.
OPLProbe 0.1 will now try to detect an OPL on port 0x388
Detected a YMF262 OPL3 on port 0x388
IO delay: read status register 1000 times in 3995 microseconds
Testing timer 1 with value 255
Timer overflow after 94 microseconds, 12 reads
Timer overflow after 116 microseconds, 18 reads
Testing timer 1 with value 127
Timer overflow after 12148 microseconds, 2870 reads
Testing timer 2 with value 255
Timer overflow after 105 microseconds, 14 reads
Timer overflow after 307 microseconds, 62 reads
Testing timer 2 with value 127
Timer overflow after 48222 microseconds, 11422 reads
Timer overflow after 48222 microseconds, 11421 reads
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
