First post, by assortedkingdede
I have been trying to use FDISK to create a partition to install windows on a 120 GB HDD. The motherboard can see the full size but FDISK keeps reporting that it made a 48 GB partition. I have created a larger partition on an SSD with FDISK but this is happening with an unformatted HDD. Any info will help. Thanks!
(PS: I discovered that I can't event create another partition because there is "No Space".)
Reply 1 of 6, by smtkr
Is it the display bug mentioned by philscomputerlab:
"Fdisk and format are 16 bit applications and can't display the full capacity. This can just be ignored and is purely a cosmetic issue. To avoid this use or create a hard drive with 64 GB or less."
https://www.philscomputerlab.com/windows-98-m … e-capacity.html
Reply 2 of 6, by Horun
There is a Win98 Fdisk fix by Microsoft. https://archive.org/details/windows-98-and-se … drive-fixes.-7z
Are you using it ?
Reply 3 of 6, by ppgrainbow
If you're not using the updated version of FDISK or FORMAT for Windows 98 or Windows 98 Second Edition, you're faced with a cosmetic bug.
When Windows 98 was released in June 1998, hard disks and other media larger than 64 GB in size were not available until the end of 2000. By the time a 75 GB IDE hard drive was introduced that year, it would only show the available capacity as 7,706 MB when initalised using FDISK and formatted. This is because, FDISK and FORMAT used unsigned 16-bit values to calculate capacities in megabytes. Article KB263044 fixes this issue and you can download the fix that Horun pointed out.
However, if you use the updated utilities, FDISK has a design limitation that it will be unable to create hard disks larger than 512 GB (524,287 MB). Also, because FDISK uses 5-digit figures to store the hard disk capacity, capacities over 97.66 GB (99,999 MB) will have the first digit omitted. To get around the 512 GB limit in FDISK, you will need to use a 3rd party hard disk partitioning utility.
Reply 4 of 6, by darry
I suggest using a bootable (USB or CD/DVD) Linux live distro's fdisk utility to do the partitioning.
There is also FreeDOS' version of fdisk, but I suggest testing things careful if you use it on an SSD and ever intend to try running TRIM on it. I experienced this issue : Corruption issue when using rloew's TRIM.EXE (TRIM utility for DOS) with FreeDOS FDISK 1.2.1/1.3.1 partitioned DISK
Reply 6 of 6, by VeryVon
For anyone resurfacing this issue, the FreeDOS versions of fdisk & format (IMHO) are lightyears ahead of the microsoft ones. Just download the FreeDOS floppy edition and you're off to the races.
https://www.freedos.org/download/
p.s. I have no affiliation with FreeDOS
