First post, by jakle
Greetings,
I am trying to compile DOSBox under Visual Studio, I have all of the libarires that I want and linked. But this is a roadblock for me.
When I compile, 6 warnings appear, "Warning C4738: storing 32-bit float result in memory, possible loss of performance" all in pngget.c from libpng.
Afterwards a error, "error LNK1257: code generation failed". Then another error "error C2220: warning treated as error - no 'executable' file generated"
How can I resolve this to compile DOSBox? I tried compiling without libpng & C_SSHOT but I got "error LNK1123: failure during conversion to COFF: file invalid or corrupt"
Reply 2 of 4, by jakle
I am using Visual Studio 2010, compiling dosbox-0.74
Reply 3 of 4, by jakle
Solved by compiling without libpng and installing VS2010 SP1.
For some reason VS2010 RTM causes those COFF errors
Reply 4 of 4, by Azarien
jakle wrote on 2022-08-02, 00:33:
Seems like this spurious warning is treated as an error.
One way of solving this would be to disable warning C4738 somewhere in project properties, alternatively you can disable treating warnings as errors.
https://docs.microsoft.com/en-us/cpp/error-me … 0?view=msvc-170
