First post, by appiah4
These adapters have become fairly difficult to source, and expensive. It should be fairly easy to hack one together with a 20pin ATX extension cable or a 24 to 20 pin ATX adapter, plus the 6pin P10 connector which can also be sourced from old/dead early ATX PSUs. The issue is, I do not have the pinout. Does anyone have it lying about?
Reply 1 of 7, by Thermalwrong
Sure, it's here: https://pinoutguide.com/Power/dell_atxpower_pinout.shtml
With some of the motherboards, you can shift the ATX connectors position to make it ATX compatible again: A Permanent Solution to the Dell 'Fake ATX' Power Supply Problem?
Here's a graphic to show how it's shifted and where the clips etc are that I just put together in Excel - I've checked this against my own Dell Dimension XPS D233 to confirm:
Reply 2 of 7, by appiah4
Oh wow that looks way simpler than I thought it would be!
Reply 3 of 7, by pentiumspeed
All you do is take a standard solder ATX connector, take out both dell connectors, and open up the solder holes for the ATX, solder the ATX connector in. Dell connector has one pin missing.
Cheers,
Great Northern aka Canada.
Reply 4 of 7, by chinny22
I like Dells of this era but jeeze it was a dick move not to use the ATX standard. Especially when it was found the motherboards even had solder points for a stranded connector
Reply 5 of 7, by appiah4
pentiumspeed wrote on 2022-08-03, 23:07:
Cheers,
I don't quite follow..
Reply 6 of 7, by ODwilly
appiah4 wrote on 2022-08-04, 05:51:
Cheers,
I can't remember who made them or the name of the threads, but Im pretty sure somewhere around here someone has solved this issue. What is described is exactly it besides using a diagram to follow along. An adapter does the same thing.
Reply 7 of 7, by PC Hoarder Patrol
ODwilly wrote on 2022-08-04, 06:06:
Cheers,
