AT Power supply tester
First post, by TrashPanda
Looking for a quick testing unit for AT PSUs, I have the digital ones for ATX PSUs but cannot find one to suit the older AT connectors.
Is there such a thing ?
If so does anyone have a link to where I can buy one ?
I know I can use a Multimeter for this but my lazy lizard brain wants a faster safer method. (I dont like sticking shit into the angry pixie end of PSUs)
Reply 1 of 6, by PC Hoarder Patrol
TrashPanda wrote on 2022-08-05, 10:30:
Looking for a quick testing unit for AT PSUs, I have the digital ones for ATX PSUs but cannot find one to suit the older AT conn […]
Maybe someone here could build you one! - http://www.dasarodesigns.com/product/pc-at-ps … ly-load-tester/
Reply 2 of 6, by Nexxen
Adrian from Adrian's digital basement had a psu tester, but I can't say if it is common or cheap.
You plug in the mains to it and it tells values for each V.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Reply 3 of 6, by kaputnik
If safer and just a little bit faster is enough, you could easily build an adapter with an AT connector in one end, and proper test points for the multimeter in the other.
Successfully used crimp-on wire terminals as test points a number of times. Connect the ring/spade/fork/whatever to the wire, multimeter probe goes into the uncrimped wire hole. 2.5 mm^2 (blue) works well with most probes 😀
Reply 4 of 6, by TrashPanda
PC Hoarder Patrol wrote on 2022-08-05, 11:21:
I found a site that builds the adaptors to switch 20/24 modern ATX PSUs to the AT plug type, im thinking this might actually be a good way around using AT PSUs until I can either buy a tester or build one myself.
Reply 5 of 6, by timw4mail
TrashPanda wrote on 2022-08-05, 11:56:
Yeah, that should generally work. The only potential issue is if you need -5V for one of your old cards. There are adapters to add that voltage, but you may not need it.
Reply 6 of 6, by TrashPanda
timw4mail wrote on 2022-08-05, 13:59:
I have to grab one of them, cheers for reminding me !
