Reply 340 of 406, by Falcosoft
crazii wrote on 2023-02-27, 07:28:
I can try it but it needs debugging and I don't have the hardware to debug it, so it's not guaranteed to work.
Thanks, I can help debugging SB Live! 5.1 and Audigy 2 ZS.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 341 of 406, by crazii
Update:
1. added option /k to set sample rate. /k22050 or /k44100, default 22050
2.added experimental support for SB Live and Audigy (not tested, probably won't work, but with initialization log enabled)
3.experimental changes on HDPMI: a) if interrupt happens in PM, then after pm handlers service the IRQ, route interrupt to IVT first - don't know this is good, but fixed Miles Sound. b) "simulate real mode int" API calls IVT first. - don't know this is good either but both changes makes Miles Sound working. I'll turn off the switch if anything previously works but now goes wrong.
4. based on 3, now PM SB virtual interrupt are using INT xx, and with original context restored. this could make protected mode games more stable.
SBEMU.zip
251.61 KiB
83 downloads
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 342 of 406, by Falcosoft
crazii wrote on 2023-02-28, 16:53:
Hi,
With Audigy 2ZS the output of the new version is no different from the previous one. Namely:
No soundcard found!
Unknown soundcard (output module) name : NUL
Reply 343 of 406, by crazii
Falcosoft wrote on 2023-02-28, 17:34:
Hi, With Audigy 2ZS the output of the new version is no different from the previous one. Namely: […]
Hi,
No soundcard found!
I added more log to show error information.
SBEMU_SBLive_Audigy_TEST.zip
200.23 KiB
56 downloads
Reply 344 of 406, by Falcosoft
crazii wrote on 2023-02-28, 18:18:
Hi,
No soundcard found!
Hi,
Interesting, but the output is still the same. Do I have to use some kind of command line argument to get more verbose output?
Reply 345 of 406, by crazii
Falcosoft wrote on 2023-02-28, 18:55:
Hi,
Hi,
I checked the code again and found one important missing change, sorry. updated in the previous link.
Reply 346 of 406, by Bondi
Update: 1. added option /k to set sample rate. /k22050 or /k44100, default 22050 2.added experimental support for SB Live and Au […]
Update:
SBEMU.zip
Now that you started adding new output devices, can I suggest a couple of more to be added to the pipeline?
1) Covox. It's very widespread and compatible with both old and new systems. Only 8 bit sound is supported, yet, the sampling rate is unlimited.
2) Sound Blaster Direct mode, 8 bit, 8 or 11 khz maximum sampling rate. Can be used on systems with a SB DSP, but lacking DMA. Which is not unulual. For instance Omnibook 600ct has a ES1668 chip, but no DMA. I thik there existed PCI cards with SB DSP. And my favourite PCMCIA cards.
This one should be the easiest to implement, as no card detection procedures are necessary, the DSP sits on a usual port. As well as FM emulation, as it can be done in hardware.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 347 of 406, by crazii
Yes, I think it'll be good to add Covox support. however for the direct mode, its' complicated. with DMA, I only copy the ISA DMA buffer from DMA controller to PCI DMA buffer accessed by PCI bus master device, that simple enough. for direct mode, even if I'm able to put the sample directly into the PCI DMA buffer, I need to resample the buffer but there's no direct sample rate information, need a high frequency timer detect it.
For now I think the first priority still be making MDK working, which was one of my favorite games in my childhood. 😁 I still play it on Steam.
Reply 348 of 406, by Falcosoft
crazii wrote on 2023-03-01, 03:32:
Hi,
I have re-tested the new version and this time it "worked" in the sense that it detected the sound card and I also heard a "pop" from my speakers (I think this is a good sign). But unfortunately testing with Duke Nukem 3D resulted in no music and no sound. The music test did not give any errors but simply resulted in silence. The digital audio test resulted in an error message that playback failed most likely because of not well configured DMA channel (or something similar in a red dialog).
523.15 KiB
Reply 349 of 406, by crazii
Falcosoft wrote on 2023-03-01, 08:56:
Hi, I have re-tested the new version and this time it "worked" in the sense that it detected the sound card and I also heard a " […]
Hi,
The most possible reason is that the interrupt is not enabled. I'll check what I can do.
Reply 350 of 406, by Bondi
crazii wrote on 2023-03-01, 07:06:
I see. However if Covox is possible, then direct mode(DM) should not be an issue. As in both cases it's basically all about sending the data byte to the IO port at a given rate.
Yeah, same here, I love MDK since it came out 😁
Reply 351 of 406, by crazii
Hi,
I wrote the wrong register to enable interrupts. now it MIGHT work, but I don't know the interrupt rate, might not work for doom's digital sound, maybe need configure a timer interrupt from the sound card.
let's see what happens first 😁 the TEST zip is updated.
Reply 352 of 406, by crazii
Bondi wrote on 2023-03-01, 13:00:
Covox might be simpler, if I'm correct, just output whatever the samples to it at whatever rate, and it's done. But there's delay on CPU (the trapping code), the sounds may be distorted.
OK I was wrong, it will only be simple if it is direct SB mode for Covox. for DMA mode, the source sample rate info of the DMA buffer still needed to be used to send sample periodically.
Reply 353 of 406, by crazii
I ran MDK with log again, the PM IRQ1 handler is hooked by DOS/4GW on initialization, MDK installs a DPMI RM vector for IRQ1, it seems setrmivec store the address to INTRMCBS.orgvec but never got a chance to call it. the only chance is to use "simulate real mode int" API.
But if it is the case, why std HDPMI with IOPL3 works?
EDIT: OK, the std HDPMI doesn't work now, I was using the one from the original site, created at the year 2009.
EDIT: if set rm interrupt vector is directly written to IVT, then MDK works. But I don't want mess up with HDPMI source code prematurely anymore. 🤣
Reply 354 of 406, by Falcosoft
crazii wrote on 2023-03-01, 13:23:
Hi,
Unfortunately the end result is the same: soundcard detected, but neither music nor digital audio works in Duke 3D. The error dialog in case of digital audio testing still complains about DMA (not IRQ).
Reply 355 of 406, by digger
crazii wrote on 2023-02-27, 07:37:
The author of MPXPlay agreed that SBEMU uses its source code, as long as its header comments unchanged, and SBEMU opens source. 😁
https://sourceforge.net/p/mpxplay/discussion/ … ead/ac6560662b/
Good to know that the Mpxplay author doesn't object to their sound driver sources being used in SBEMU, but didn't you also integrate Sound Blaster emulation code from the DOSBox project? That code is likely licensed under the GPL, which doesn't allow it to be mixed with sources that have a more restrictive license. "You can't use this to make a clone of certain other software" is an additional restriction that the GPL doesn't have, and therefore make DOSBox sources and Mpxplay sources incompatible with one and other.
As long as the DOSBox developers don't mind this, I guess you could at least continue developing it further like this for the time being, but they legally have a right to object to this.
I would still recommend replacing the sound hardware driver sources from Mpxplay with alternative sources with a more permissive license.
The Open Sound System (OSS) driver sources from 4Front Technologies would fit the bill: they have been released under multiple open sources licenses, including 2-Clause BSD and GPL 2.0, and support a wide range of contemporary sound devices, including pretty much all the popular ones: Intel HDA, ICHx AC'97, Sound Blaster Live!, Audigy, and many others. The OSS drivers are multi-platform in the sense that they are intended for POSIX (UNIX-like) operating systems, but could perhaps be ported to DOS. Such a port would yield benefits not just for SBEMU, but for many other open source DOS sound projects as well.
I would guess that one major piece of "glue" that such a DOS port would require would be the PCI access stuff, so implementations of "pci.h" and such. That could perhaps be adapted from other open source DOS projects.
I'm sorry if I'm coming off as a bit pedantic when it comes to open source licenses and compliance and such, but open source projects have gotten in trouble over these things, and SBEMU is too cool to have it blocked or complicated by something like this.
Reply 356 of 406, by ptr1ck
I think I may have a candidate machine ready to test out since I don't have a PSU on hand to power my Nforce2. It's a an Intel Z77 with an X-Fi Titanium. Where can I get a current version to test this?
"ITXBOX" SFF-Win11
KT133A-NV28-V2 SLI-DOS/WinME
Reply 357 of 406, by crazii
Falcosoft wrote on 2023-03-01, 15:47:
Hi,
The interrupt is probably enabled now so IRQ is OK, but the IRQ rate is low and Duke3D doesn't detect DMA counter/pointer changes, since they're updated in the interrupt handler. I'll try the timer of Audigy2ZS or some undocumented ways.
Reply 358 of 406, by crazii
digger wrote on 2023-03-01, 22:40:
OK, I didn't know DOSBox has such restriction, Does that makes DOSBox source code not reusable for any purpose? Even the clone of DOSBox, like DOSBox-X or DOSBox-SVN-Daum are not permitted?
Use another sound card driver can be done but it is expensive, meaning starting over and testing again for every games, I'm not ready to do this. I think use another OPL emulation code might be more easy.
Reply 359 of 406, by crazii
ptr1ck wrote on 2023-03-01, 23:37:
Here it is: Re: Possibility to write OPL3 sound driver for protected mode games
