First post, by rarcher
Good evening everyone! Sorry about the likely odd thread title, but I was not quite sure how to word this exactly.
So I am still working on outfitting my IBM Valuepoint 486DX2/66 6482 model. As I mentioned in my mid-life crisis thread I ran into some road blocks/set backs with some stuff. But while working to fix those issues, I happened to be looking at the IBM manuals for this that list parts/options for the different models.
As you can see here mine is one of the 6th to the 4th options from the bottom, the 6482's. These have a VLB slot which then uses a riser card to add ISA and a VLB port on it. But the 6484's, the last three near the bottom there have a VLB slot which uses a riser card that gives 2 ISAs and 2 PCIs (maybe a single VLB too? Not sure). So I got to wondering as the second picture above shows the ISA/PCI riser option was an add on for 115 bucks back then. So I'm curious if anyone could tell me if I was somehow able to find this card do you think it would work in my 6482? Or is it likely only something the 6484s got? I only wonder on this, because if I could get PCI on this PC it would solve alot of my headaches I'm having with price and such in getting say better soundcard or ethernet card, maybe even a PCI based graphics card.
I've also included the ISA/PCI raiser part number from the booklet but googling this part number doesnt turn up anything sadly.
Basically my intention is to possibly get either a good workhorse gaming oriented graphics card (ISA/VLB or if this idea works PCI), same for a soundcard and ethernet card.
I'll be diving into reading up on the forums here about isa/vlb card options but from a glance so far when then looking to options given I'd be paying too much for what I want. So I'm figuring given I don't plan to do much gaming for now focus on the ethernet and sound card options (again i'm not audio nut guy so having a good 'all around workhorse' sound card would be ideal) seems though in both cases PCI options seem more viable in price then ISA/VLBs
Can anyone enlighten me on this? Or perhaps provide a better suggestion in some form?
Thanks again!
