First post, by Chadti99
Browsing CPU shack I noticed a part number for a Cyrix 5x86 with no marked clock speed. Why were these made? What speed are they?
Reply 1 of 4, by debs3759
I think the only guarantee, if they work, will be that they work at 3 x 25 MHz. No idea why they have no speed marking. I guess it's just another lottery. You might be lucky, if you find one, and get it running at 4 x 33, or even better (and an overclock) at 4 x 40
Reply 3 of 4, by rmay635703
g5lb601c Was 120mhz or 133mhz on all the chips I’ve seen with that code.
Why the actual speed isn’t marked no idea
