First post, by DrLucienSanchez
- Newbie
Hi Guys,
I have been running a Pentium III Katmai at 550Mhz on my 440BX MS-6156 mobo. I originally ran a Pentium II at 400Mhz.
According to the datasheet here for the SC1152CS regarding Vcore, it says the max ampage is 15A for load regulation - https://pdf1.alldatasheet.com/datasheet-pdf/v … H/SC1152CS.html
But according to this page here - https://www.pchardwarelinks.com/elec_pentium.htm - the max load for this specific CPU is 17A.
Windows, benchmarks have been fine, but a couple of times I have had a no-signal on boot, but when removing all drives, CPU socket, GPU and putting them back in, it works fine, but this maybe due to a loose IDE to SATA converter as it;s a tight fit, so may just be a coincidence, but on a whole am I doing any long-term damage running the Pentium III, too much load on the SC1152CS, or reducing its lifespan.
Many thanks.
