First post, by Danger Manfred
Hi,
I was transporting my Cherry MX 1000 G80 in parts (loosely put together) when they fell to the ground, the bottom case part went a different direction than the PCB on impact, and the AT/XT dip switch came off.
What's worse is it was on my balcony and seems to have fallen down from there, I'm completely unable to find it.
Other than that, I see no damage on the PCB, pictures of both sides of it, and where the dip switch supposedly sat, attached.
When I connect the PCB to any PC, I can use the caps, num and scroll lock keys to make the corresponding keys light up, but no keypresses are registered by the computer.
So anyway, I want to repair this, since it should in theory be fairly easy - all I need is connect two points so it's in permanent AT mode, I have no XT PC and don't plan on ever getting one.
But the problem is: I don't know how it is supposed to look where the switch was. I had hoped to find a schematic or a photo of an intact PCB, but couldn't find any.
Does anyone have an idea where I could get such a picture?
edit: added a picture of the info sticker
