First post, by Aceuk
I dont know if anybody tryed this . right click on the dosbox icon .went into properties,Then goto compatibilty .Then put a tick, In run in 640+480 screen revolution .
it workes just fine dosbox in fullscreen i thought i post this just in case people are having problems geting dosbox in full screen
Ace
Reply 2 of 16, by guala
hi, using dosbox in fullscreen I can' t see the enlarged image of game but only a black screen having the game window within.
Did someone experienced the same problem? I trie on other PCs without having the same problem. Further, the cmd fullscreen is not enlarged too!!!
Thanks for helping me!!!
Reply 3 of 16, by Qbix
Rank DOSBox Author
DOSBox Author
you probably have a laptop.
little you can about it.
Water flows down the stream
Reply 4 of 16, by `Moe`
Read what dosbox.conf has to say about "fullfixed" and "output". Play with those settings.
Reply 5 of 16, by D-xiansheng
Maybe I'm missing something, but what's wrong with just using ALT+Enter ...? I run DOSBox games in fullscreen on my laptop that way just fine.
Reply 6 of 16, by `Moe`
Computers with LCD displays sometimes can't switch display resolution, that's why some people just see a small area of dosbox in fullscreen mode. Using hardware scaling with fullfixed fixes that.
Reply 7 of 16, by D-xiansheng
Wouldn't you just be able to set DOSBox's scaler to match your desktop resolution in fullscreen then?
Reply 8 of 16, by `Moe`
You have to configure it yourself (using "fullfixed" and "fullresolution"), but that's what those two options do. It's not default because it needs an output mode with hardware scaling, which is hard to autodetect.
Reply 9 of 16, by D-xiansheng
Yeah, that's what I ended up doing when I installed DOSBox.
Is there a way to force aspect ratio or create black regions? Even in 1024x768 my screen scales everything. I have a widescreen monitor so it ends up at in 3:2 ratio when viewing even if the video card is outputting something 4:3 (though most games really don't look bad with that kind of stretch ...)
Reply 10 of 16, by `Moe`
Does your screen have square pixels? (i.e., does the physical size (in mm) of your display have the same aspect ratio as the logical resolution (pixels)?) If yes, then set fullresolution=<your native resolution> and dosbox should create appropriate borders. If you don't have square pixels, I think you're out of luck there. If you know a little C++, you could modify your personal copy of dosbox so it takes that into account.
Reply 11 of 16, by D-xiansheng
Yeah, I have square pixels, bot it's still stretching it hard when set to my native resolution.
I'd take a shot at it but I don't have a C++ compile environment set up on this computer. I probably wouldn't succeed anyway since I dumped C++ 5 years ago in favor of PHP for speedy console application development. (I never have and never really needed to write anything requiring a GUI)
Reply 12 of 16, by gulikoza
My D3D patch for Dosbox has an option to display 4:3 output on widescreen displays. You might wanna take a look at it...
Reply 13 of 16, by D-xiansheng
What's the option? I have a CVS build with you patch but I don't know what option I need to add to my .conf file.
[sdl]
fullscreen=true
fulldouble=false
fullfixed=true
fullresolution=1280x800
output=direct3d
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[render]
frameskip=0
aspect=false
scaler=hq2x
Reply 14 of 16, by gulikoza
aspect=true 😀
Reply 15 of 16, by D-xiansheng
As 8 seconds of Google searching did not yield a smiley beating itself in the head with a hammer, I'll just say, "Thanks."
Reply 16 of 16, by `Moe`
I wonder why it is stretching hard... with output=opengl, it keeps aspect ratio for square pixels (which means a little stretching for non-square-pixel modes like 320x200) - with an unpatched Dosbox.
