First post, by kalgon
I saw on other threads that Gravis Ultrasound cards could be upgraded with memory chips typically found on S3 graphic cards.
I have this dead S3 card so I was wondering if I could use its memory on my GUS. The chips references are "TD 51825VJ-50" and "S416257DJ-7S".
1.75 MiB
S3 Trio 64V+
Thanks!
Reply 3 of 3, by CHiLL72
kalgon wrote on 2022-08-24, 11:23:
It's a GUS Max 2.1.
Then these should probably work just fine!
Waveblaster MIDI boards: https://waveblaster.nl - online now!
