First post, by andrew_241
Hello!
I obtained a 386DX motherboard (ECS 386A), and am having a problem with the keyboard not responding after the memory test is complete.
The system will check all 8192 KB of RAM, and I can skip it by pressing 'ESC' (all 8192 KBs of RAM are tested otherwise, and no errors are reported.) After that, a message on screen reads "Press <DEL> If you want to run SETUP/EXTD-SET". The POST does not proceed further. Pressing 'DEL' doesn't do anything, however. Holding down 'DEL' does result in the system speaker repeating a buzzing sound after about a second, which repeats on any keypress. I've checked that keylock is not enabled. No HDD or floppy disk is installed. I connected an external CMOS battery (haven't checked that it's good), but it doesn't make a difference. Perhaps the battery is dead, so I ordered a new one.
The only ISA card installed is a Trident 8900D VGA adapter. The floppy and HDD controller card is not installed. The problem still exists with the controller card installed.
Any ideas?
Thanks!
