First post, by Synaps3
This motherboard is very annoying! I read one other post on google about someone having a similar issue that was not resolved.
Basically what happens is about 50% of the time, the board will lock up on boot or when trying to enter the BIOS. Once the thing boots up, it's perfectly stable. Sometimes it seems to just be the keyboard controller getting bugged out cause I can unplug and replug the PS/2 keyboard and that will occasionally let me work in the BIOS.
If I leave the system off, but plugged in (PSU switch on) for a few days, when I come back, it always BSODs windows on boot. I have to reboot, unplug/replug the keyboard, and reset the BIOS. Warm reboots seem to fail 100% of the time. It will never warm reboot. If I'm having an issue, I usually have to completely power off the thing for several minutes to get it to work again.
I have not updated the BIOS yet (which I will do), but the other guy with the issue said that didn't help.
It's really pretty random, but there are some small patterns to it. I thought it could be a bad cap, but I'm thinking otherwise now because why would it be perfectly stable once it's finally booted windows? There are no buldging caps. I can't put the mobo in a case until I figure this out because I need to remove the battery often. Any suggestions or similar experiences?
(I don't want to just get a new mobo unless I have to cause I always spend a lot of time customizing the OS and don't want to start over again.)
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
Reply 1 of 6, by rasz_pl
Synaps3 wrote on 2022-08-28, 20:06:
Because bad caps get better when warm. You can test this theory by unplugging it from power for a day, using hair drier to heat cpu power area and then power on
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 6, by Synaps3
rasz_pl wrote on 2022-08-29, 16:56:
Thanks, I'll try that. I'm also going to try to check the caps. I should mention none of them look bad.
But does anyone else here have a KT880 board (any brand)? I'm curious if this is just a buggy platform to begin with. I stopped using MSI boards in my modern builds because of BIOS problems, so I'm wondering if this was just one of those boards that had a bad BIOS? I doubt it could be this bad and people would still put up with it though.
Systems:
Reply 3 of 6, by Nexxen
Could be a faulty bios chip.
Not unheard of.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 4 of 6, by Synaps3
It's still not resolved. I just ignored it for a while after trying everything apart from replacing caps that ALL look completely fine. Not to mention, why would it then be 100% stable once inside Windows. Makes no sense. It's got to be some weird BIOS thing. I've had other MSI boards with BIOS issues. Seems to be a theme with this brand. I can tell the BIOS is not quite the standard "Energy Star" with the text in the exact normal format for a BIOS.
I started looking for new motherboards, but I'm kind of constrained cause I want support for Dual Floppy drives, DDR400, and Athlon XP 3200. It would significantly open up my options if there was some PCI (NOT ISA) floppy controller that supports two floppy drives, but they don't seem to exist, so I'm fully reliant on the motherboard having that feature.
I want to buy another MSI KT880 Delta OR a gigabyte GA-7VT880. Anybody have one? I will pay significantly more than it's worth. I don't want to deal with this anymore.
Systems:
Reply 5 of 6, by shevalier
Synaps3 wrote on 2022-08-29, 19:27:
Platform is normal, implementation is like usual 🙁
I have K8T800as from jetway, and it`s peace of crap
it's you in vain, it`s first to need do. Even no measure capacitance and ESR, just replace right away.
gigabyte GA-7VT880
Of those schematic diagram of matherboard that I have seen, Gigabyte is the least weird.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 6 of 6, by Synaps3
I ended up finding a GA-7VT880. It's a super rare board, but I found it on a Polish site (I don't read Polish). I didn't have the equipment to replace the caps on the MSI at my new place and didn't want to buy stuff just to find out it doesn't fix the problem anyway. Considering that the MSI board has such a weird BIOS which is not the standard Award Energy star. Instead, it's got MSI logo there and the text is a little weird - like not from a native english speaker. Clearly a modded BIOS by MSI which is probably buggy.
The Gigabyte just arrived and I love it so far. I think it's the best Socket 462 board (and clearly one of the latest releases). It has a VRM cooler (small, but other boards don't have any). I compared side by side from photos KT600 and KT800 boards by MSI, ASUS, and Gigabyte. MSI and Gigabyte seemed to have better physical quality. The ASUS was lacking many capacitors and the VRMs were way TOO SMALL. So I went with Gigabyte cause it had best physical quality and the BIOS was a normal traditional Award energy star with no weird modifications.
I just did a memtest on the GA-7VT880 and it's perfectly stable. No locking up like the MSI. I'm happy to stick with this board.
Something to note: I'm not sure if the dual floppy support is going to work though. The BIOS does support it and the manual says it supports, but when I booted Windows PE, the floppies had tons of errors "no disk exception..." Cancel, Try Again, Continue. And these drives worked fine on an older PIII board with VT82C686B southbridge. I selected the right Drive A and B in BIOS (doesn't have swap A, B though 🙁 Maybe once I actually install Windows, it will work.
Systems:
