First post, by sayjionix
Hi,
recently I started the restoration of an IBM 5150 in my collection and while checking out the motherboard, I stumbled upon some RAM chips that have absolutely no marking or label at all (neither on top nor on the back). Also looking at them under the microscope shows no trace of deteriorated or just badly visible markings.
The attachment IBM_5150_RAM.JPG is no longer available
I have the 64KB-256KB motherboard version, so all banks should be populated with 4164-type RAM chips to reach the 256KB, and also Switch 1 and 2 were configured for 256KB.
First I thought those might be dummy or placeholder chips (is that even existing?), but after successfully bringing the 5150 up to live again, PC DOS 3.3 shows 216848 free bytes out of 262144 bytes total memory. There is also no 201 POST error, unless I remove one of those unmarked chips on purpose. Then I get the correct 201 error indicating the location of the removed chip together with a parity error. That let's me assume that those are indeed working RAM chips.
Has anyone of you ever seen those completely unmarked memory chips? Was that common at that time? Did they have a special purpose?
And moreover, is there any more thorough RAM test program for the 5150 existing?
I would be really curious to find out more about those chips!
Reply 1 of 3, by pentiumspeed
Could be low quality ram purchased somewhere weird place and as time goes on, owner had to replace few with another chip as they fail over time?
One more thing, you can add a ttl IC and jumper one other IC then swap first two banks with eighteen 256K DRAMs to reach 640K for that board. I did this as instructed back then and this worked. But problem is the first bank is soldered. Groan.
Cheers,
Great Northern aka Canada.
Reply 2 of 3, by sayjionix
Thank you very much for that hint! It sounds very interesting! Do you have any more detailed info about that mod or know where I would need to search for it?
