First post, by Brawndo
I have an Acer AP43 486 motherboard with an Intel DX4 CPU which upon POST, displays the following:
The only things connected are a video card in the top PCI slot and one stick of RAM. I don't have an AT keyboard right now to enter BIOS setup (though I have one on the way). Just curious if there's a "most likely" reason here for this message. I am going to clear the CMOS later, though it did not have a battery when I received it so it should already be cleared. I have checked the jumpers for the CPU settings and they appear to be correct. I have not checked the jumpers for the installed cache yet, so I'll check that later as well. What else should I specifically be checking?
Ok I just did another search since I didn't specifically look for "CMOS display type mismatch" and I guess maybe that's it? Forgive my lack of knowledge here but I didn't get into computers until the late 90s so I missed the 486 era. I've never had to set the display type, I assume that's in the setup? Does the setup retain settings even with no CMOS battery installed? The video card is a Diamond Stealth 3D 2000 PCI.
Sucks I can't do anything with BIOS options until my AT keyboard arrives. First world problems I guess.
Reply 1 of 2, by Horun
Brawndo wrote on 2022-09-01, 23:50:
Yes it lost its CMOS settings. No it does retain settings with no battery. You need to install a battery and set the BIOS options, when your keyboard arrives.
BTW: some older PS2 keyboards will work with a PS/2 Female to AT Male Keyboard Adapter.
Reply 2 of 2, by Brawndo
Horun wrote on 2022-09-02, 00:49:
Yeah I know about the adapters, I don't have any of those either 🤣. It's alright though I wanted a legit AT keyboard anyway for this PC, got one for a good price NIB and it's on the way.
