Descent
First post, by Mike
Specs:
Pentium 1 200 Mhz
IBM PC-DOS 6.3
Sound Blaster 16 ISA
Ok, here is the problem, problem is that I can't get the game won't run because of a DOS4GW general fault error. I have DOS4GW. But, I do not understand why every time I try to play a true 3-D game on IBM PC-DOS, I get this stupid error. This crap did not occur on my Windows 95 machine, which is the one that is taken apart... Is there any way to solve this? Do I mess with any system config files?
Reply 1 of 2, by eL_PuSHeR
If you are running native ms-dos I would swap IBM PC-DOS 6.x for IBM PC-DOS 7.0 or Microsoft's MS-DOS 6.22 - Not every ms-dos version out there is the same.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Mike
Ok, thanks for the advice, I might as well get the whole version to run the port on my PC (Newer one.)
