First post, by Zeether
Zeether
Offline
I've been using dgVoodoo with F-22 Lightning 3 and it seems to work good as opposed to just using nGlide because for whatever reason with the latter it runs the game in fullscreen but with a window border and 1920x1080 is cut off, problem is with 1920x1080 resolution in dgVoodoo the performance takes a huge hit especially in the cockpit view with the instruments on. I'm not sure how to fix this. Is it better to use nGlide and if so, how do I fix the weird window in fullscreen? Is there some setting in dgVoodoo that will improve the performance?
