First post, by Lylat1an
Hello, I would like to get an 8-bit ISA VGA card for testing older motherboards on a modern monitor.
Do any reputable examples come to mind that aren't over $100 on Ebay?
I remember having one long ago that 'just worked' without DIP switches nor jumpers, but it was expensive and I can't remember its name. (I think it was made by ATI or possibly AMD)
If a card with jumpers/DIP switches is advised, I'll need to have access to the manual online too.
Thanks.
Reply 2 of 15, by Horun
As Sphere478 said: There are some decent 16bit 256k to 1Mb VGA cards that work fine in 8 bit slots with few jumpers or switches. There are also some 8bit but as you said are relatively expensive.
Note: there are some issues using 1Mb VGA on XT depending on bios and motherboard. I cannot find the topic here or my list but these work well in later XT clones. From my box of 8/16bit VGA:
Most OAK OTI037C based. Example Hedaka HED-622. One jumper to switch 8bit/16bit bus. Old MHL V0066 but does not show a jumper at bottom of ram that changes 8bit or 16bit: http://www.uncreativelabs.de/th99/v/E-H/50066.htm
Many TVGA Trident 8900 or 9000 ISA. Jumpers to change 8/16bit. Example: Jaton JX-8216A http://www.uncreativelabs.de/th99/v/I-L/51651.htm or http://www.uncreativelabs.de/th99/v/P-R/50859.htm
Many Acumos AVGA1 <Cirrus Logic CL-GD5401> based (aka GTK VGA1) based, either one or no jumpers {Auto detects}. https://www.vgamuseum.info/index.php/cpu/item … 01-acumos-avga1
Mine is this one: https://www.vgamuseum.info/images/vlask/cirrus/5401f.jpg but branded Acumos/GTK...
Reply 3 of 15, by Veeb0rg
Sphere478 wrote on 2022-09-16, 02:18:
You should be able to plug in a 16-bit card and let the extra hang over
My parents first XT Clone ran like that for years. Had a 16bit card in an 8bit slot and worked perfectly.
Reply 4 of 15, by TheMobRules
I use a Paradise PVGA1A-JK with 256K, it's obviously slow but that doesn't really matter in an XT class system. The good thing is that it provides excellent compatibility and very good image quality. And it has no jumpers/switches.
My card is 8-bit, but 16-bit versions should work fine on 8-bit slots also. No idea about current prices, I got mine for just a few bucks some years ago (it's nothing special really) but knowing current trends there are probably sellers trying to fetch > $100 on eBay or something like that. Personally I wouldn't pay more than $25 for one.
Reply 5 of 15, by keropi
you can always build Sergey's ISA SUPER VGA: http://www.malinov.com/Home/sergeys-projects/isa-supervga
or just get a crappy VGA card with a realtek chipset - they are slow but they work in both 8/16bit slots
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 6 of 15, by Sphere478
keropi wrote on 2022-09-16, 06:48:
That reminds me, there is another one called the graphics gremlin or something rather.
Sphere's PCB projects.
Reply 7 of 15, by keropi
Sphere478 wrote on 2022-09-16, 07:11:
isn't it a CGA card though? I do not think it does VGA
Reply 8 of 15, by Sphere478
keropi wrote on 2022-09-16, 07:28:
You may be right.
Edit: yep,
https://github.com/schlae/graphics-gremlin
My bad.
Reply 9 of 15, by Anonymous Coward
Pretty much any ATi vgawonder or oem “1024”should work in an 8 bit a lot. The ones with the 9 pin digital connector are best.
Reply 10 of 15, by Moogle!
Anonymous Coward wrote on 2022-09-16, 08:09:
Just a word of warning, the Xi-8088 systems don't seem to like these cards.
Reply 11 of 15, by Jo22
There's a thread at vcfed about VGA cards with 8088 friendly BIOSes, I vaguely remember.
Edit: Was it this one? https://forum.vcfed.org/index.php?threads/8bi … ga-cards.26866/
Reply 12 of 15, by noshutdown
indeed, 8bit isa vga cards are not that common to find.
and i wonder if there are any vga chips with only native 8bit bus interface, rather than a chip with 16bit bus support placed on 8bit pcb?
Reply 13 of 15, by mkarcher
noshutdown wrote on 2022-11-18, 04:56:
The IBM VGA is a design based on an 8-bit bus interface. Actually, the VGA is called "video graphics array", because that's the name of one of the custom gate array chips in the IBM PS/2 model 50. This chip has an 8-bit bus interface. The "IBM PS/2 display adapter", which is the official name of the IBM ISA card featuring the video graphics array from the PS/2 model 50, also is an 8-bit ISA card designed to work with all IBM PC computers starting at the original PC. The first generation clone chips also were designed with that 8-bit bus in mind.
Take a look at
I wonder whether some of the 16-bit VGAs with early chipsets, like the PVGA1K or the ATI 18800 actually support 16-bit VGA memory/register access, or they just provide 16-bit BIOS access, and still limit VGA cycles to 8 bits.
Reply 14 of 15, by waterbeesje
For lolz I once plugged an ET4000AX into an 8bit IBM model 30 and just worked without any hesitation and no jumpers.
Also had several Trident TVGA 8900 and 9000, Oak 037 / 077 / 087, Realtek, Chips&tech, UMC 408 plugged in Turbo XT board without problems. Most without jumpering
Stuck at 10MHz...
Reply 15 of 15, by clb
I've got a catalog of VGA cards that I was testing on a Turbo XT clone (8 MHz) and a 25MHz 386 SX. My observation was that several VGA cards did not play well with Alley Cat. In the end I remember I settled on a ATI 28800-5 (or a ATI 28800-6 maybe?) card, that did run Alley Cat well.
