First post, by Excelsior
Hello everyone,
I received a processor AMD K6-2 (450 mhz). The processor is in a good state with one exception - it's missing a pin, more precisely pin AN 37 (Vss) situated in the exact opposite corner of the matching indicator on the corner of the CPU.
In the diagram from the link it's the pin in the upper right corner - https://www.pchardwarelinks.com/586pin.htm
Or here at the pages 267 and 268 (the same upper right corner) - https://www.digchip.com/datasheets/parts/data … /AMD-K6-pdf.php
I don't have a socket 7 motherboard at the time but I will receive it next week.
My question is: will the processor work without that pin or not? If not is there a way to make it work, for example replace the pin with another metal as similar as possible with the original?
Thanks in advance!
